what error is it ?
:confused:when I run a solver which was writen by myself,there is an error like follows:
--> FOAM FATAL IO ERROR: attempt to read beyond EOF file: /home/cfd/OpenFOAM/cfd-2.1.0/run/tutorials/incompressible/rkcpFoam/cavity/system/fvSchemes::divSchemes::div(Y3) at line 36. From function ITstream::read(token&) in file db/IOstreams/Tstreams/ITstream.C at line 83. FOAM exiting how can I handle it? thank you!! |
You can get this error if the dictionary (input file in your case directory) is improperly formatted.
thank you !! it may be not this cause, because I use an example of one case of OpenFoam. |
