Home > Forums > OpenFOAM Programming & Development
how to implement fixedMean in groovyBC?
Like Tree1Likes
  • 1 Post By cosimobianchini
Old   June 29, 2013, 13:33
Default how to implement fixedMean in groovyBC?
immortality's Avatar
Ehsan
immortality is on a distinguished road
there is a BC for outlet named fixedMean.
it seema its main code is this:
void fixedMeanFvPatchField<Type>::updateCoeffs()
    if (this->updated())
        return;
    Field<Type> newValues(this->patchInternalField());
    Type meanValuePsi =
        gSum(this->patch().magSf()*newValues)
       /gSum(this->patch().magSf());
    if (mag(meanValue_) > SMALL && mag(meanValuePsi)/mag(meanValue_) > 0.5)
        newValues *= mag(meanValue_)/mag(meanValuePsi);
    else
        newValues += (meanValue_ - meanValuePsi);
    this->operator==(newValues);
    fixedValueFvPatchField<Type>::updateCoeffs();
what does it do exactly?is it possible to implement it to groovyBC?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   July 1, 2013, 05:37
cosimo bianchini
cosimobianchini is on a distinguished road
Send a message via Skype™ to cosimobianchini
Well, it reads patch internal values:
It calculates and area averaged value:
Type meanValuePsi = gSum(this->patch().magSf()*newValues)/gSum(this->patch().magSf());
Then, if the prescribed reference value (meanValue_) is not zero and the difference in magnitude between internal values and meanValue_ is higher than 50%, it scales the local imposed boundary value with the ratio between the desired and the obtained mean values otherwise the adjustment of boundary values is provided with a shift to correctly set the mean value. In both cases the newValues exactly fulfill the requirements of prescribed mean value.
else
Concerning the implementation in groovyBC, even though I'm not expert, I'm pretty sure you can implement this using the valueExpression.
As I can see in fact, all the the required functions (sum,internalField,Sf and conditional operator) are implemented in groovyBC.
immortality likes this.
Cosimo Bianchini
Ergon Research s.r.l.
Via Panciatichi, 92
50127 Florence - ITALY
Tel: +39 055 0763716
Mob: +39 320 9460153
e-mail: cosimo.bianchini@ergonresearch.it
URL: www.ergonresearch.it
cosimobianchini is offline   Reply With Quote
Old   July 1, 2013, 09:30
Ehsan
Hi
thanks.
newValues are replaced to the internalField,right?
I don't think such a function there is in groovyBC to change internalField values unless dear Bernhard say something else.
Old   July 1, 2013, 10:10
cosimo bianchini
No. newValues are imposed on the boundary as new fixedValue values.
and that is what valueExpression does in groovy BC (if I did correctly understand groovy BC wiki, never went inside the code for further details sorry)
Cosimo Bianchini
Via Panciatichi, 92
Old   July 1, 2013, 11:31
Ehsan
OK.then it fluctuate around the specified value according to internal values.
its so: BC*(neighbor value)/(mean of neighbor values)
is it useful to use such a boundary in the case I've attached in the related topic?
its a closed area that a part of right wall is opened.it seems that the pressure doesn't decrease to the value I've set.I guess its a physical feature rather than numerical if you agree.
why fixedValue pressure makes neighbor cells incorrect values
I'll be thankful if you take a look into it.
Old   July 1, 2013, 12:15
cosimo bianchini
Rather than fluctuating (never used for transient cases) I would say it converges to a profile which is in equilibrium with the internal solution maintaining the specified mean value.
They case you posted in the other thread is barely understandable so I cannot give any suggestions.
Cosimo Bianchini
Via Panciatichi, 92
Old   July 1, 2013, 13:04
Ehsan
they are simple.one is a tube full of a fluid at rest in 1800000 pa that its boundary opens completely to 800000 pa BC and another opening is smaller than previous case.but if you see vectors near the opening could see a unstable situation on neighbor cells of opening patch.
Old   July 2, 2013, 03:32
cosimo bianchini
With such a pressure ratio I don't think it is a good idea to put a fixed pressure BC at the discharge orifice. I believe your convergence problem are not related to the type of pressure boundary conditions but to the position of the outlet.
Cosimo Bianchini
Via Panciatichi, 92
Old   July 2, 2013, 03:41
Ehsan
i want an outlet with minimum of pressure that can be reaced by the flow.
Then What BC you suggest other than fixed pressure BC?
I can't changeThe geometry of problem,its fixed.
Its a physical(maybe flow can't reach to a pressure lower than a limit that i don't know whats that limit) problem or numerical in your opinion?
Thanks for consideration.
Thread Tools
Trackbacks are On
groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Running, Solving & CFD 24 March 1, 2015 08:16
Boundary Conditions with GroovyBC, Normal Gradient treima OpenFOAM Running, Solving & CFD 29 September 18, 2014 10:56
parabolic velocity profile with fluctuations (groovyBC?) newOFuser OpenFOAM 17 July 15, 2013 17:27
Boundary Conditions with GroovyBC, Normal Gradient treima OpenFOAM Programming & Development 2 January 26, 2013 03:37
groovyBC and Eqn.setReference() benk OpenFOAM 3 June 2, 2011 08:49
