List of plane
Old   January 31, 2012, 11:05
Default List of plane
Mjoelnir is on a distinguished road
Hi Everyone,
i want to create a list of planes
    vector n (0, 0, 1);
    point d (0.25,0.25,0.25);
        plane cutPlane(d,n);
    scalar a(1);
    List<plane> b;
    b.append(cutPlane);
but the compiler yells at me:
In file included from /opt/openfoam201/src/OpenFOAM/lnInclude/List.H:259:0,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/HashTable.C:30,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/Istream.H:184,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/ISstream.H:40,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/IOstreams.H:38,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/VectorSpace.C:27,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/VectorSpace.H:167,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/Vector.H:44,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/vector.H:39,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/point.H:35,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/tetPointRef.H:34,
                 from /opt/openfoam201/src/meshTools/lnInclude/momentOfInertia.H:40,
                 from volFoam.C:32:
/opt/openfoam201/src/OpenFOAM/lnInclude/List.C: In member function ‘void Foam::List<T>::setSize(Foam::label) [with T = Foam::plane, Foam::label = int]’:
/opt/openfoam201/src/OpenFOAM/lnInclude/List.C:367:5:   instantiated from ‘void Foam::List<T>::setSize(Foam::label, const T&) [with T = Foam::plane, Foam::label = int]’
/opt/openfoam201/src/OpenFOAM/lnInclude/ListI.H:99:5:   instantiated from ‘void Foam::List<T>::append(const T&) [with T = Foam::plane]’
volFoam.C:120:19:   instantiated from here
/opt/openfoam201/src/OpenFOAM/lnInclude/List.C:331:41: error: no matching function for call to ‘Foam::plane::plane()’
/opt/openfoam201/src/OpenFOAM/lnInclude/plane.H:139:9: note: candidates are: Foam::plane::plane(Foam::Istream&)
/opt/openfoam201/src/OpenFOAM/lnInclude/plane.H:136:9: note:                 Foam::plane::plane(const Foam::dictionary&)
/opt/openfoam201/src/OpenFOAM/lnInclude/plane.H:133:9: note:                 Foam::plane::plane(const Foam::scalarList&)
/opt/openfoam201/src/OpenFOAM/lnInclude/plane.H:129:9: note:                 Foam::plane::plane(const Foam::point&, const Foam::point&, const Foam::point&)
/opt/openfoam201/src/OpenFOAM/lnInclude/plane.H:126:9: note:                 Foam::plane::plane(const Foam::point&, const Foam::vector&)
/opt/openfoam201/src/OpenFOAM/lnInclude/plane.H:123:9: note:                 Foam::plane::plane(const Foam::vector&)
/opt/openfoam201/src/OpenFOAM/lnInclude/plane.H:62:1: note:                 Foam::plane::plane(const Foam::plane&)
make: *** [Make/linuxGccDPOpt/volFoam.o] Fehler 1
but the list works fine i write
    scalar a(1);
    List<scalar> b;
    b.append(a);
Thank you for your help
Best regards
Henning
Mjoelnir is offline   Reply With Quote
Old   January 31, 2012, 11:15
Tomislav Maric
tomislav_maric is on a distinguished road
The plane is missing an empty constructor, just add
plane() {};
in the public interface part of the class plane, or better yet, check out the latest version of OpenFOAM-1.6-ext (if this is what you are on), it has been fixed in the meantime, and compile the library only.
Means: I really need the function (constructor) plane(), but I can't find one.
Now, tell me, what are you using this for?
tomislav_maric is offline   Reply With Quote
Old   January 31, 2012, 11:48
i want to create the class cellcuts. For that i need the list of plane for the consructor.
In the end i want to calculate the volume of the cell cutted by the plane.
Old   January 31, 2012, 12:03
Thank you for the quick response
im trying to change plane.C and plane.H
Old   July 4, 2013, 05:37
Lev
levka is on a distinguished road
Did you manage to figure out how to define a object of "class plane"??
levka is offline   Reply With Quote
Old   July 4, 2013, 06:42
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Use PtrList<plane>.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   July 4, 2013, 07:06
Lev
Originally Posted by l_r_mcglashan View Post
Use PtrList<plane>.
const point& p1=vector(0,0,0 );
const point& p2=vector(0,0,10 );
const point& p3=vector(0,0,20 );
PtrList<plane> Myplane(p1,p2,p3);
where is mistake?
Old   July 4, 2013, 07:09
PtrList<plane> planes(3);
planes.set(0, new plane(point(0,0,0)));
planes.set(1, new plane(point(0,0,10)));
planes.set(2, new plane(point(0,0,20)));
Good luck!
Old   July 4, 2013, 08:05
Lev
Good luck!
 error: ‘plane’ was not declared in this scope
And another code
point xyz(0,0,0) ;// choose the point through which //the plane goes
vector dir(0,0,1) ;// normal direction
plane plane1(xyz,dir);
cuttingPlane plane1(mesh, plane1);
gives an error:
error: ‘plane’ does not name a type
error: ‘cuttingPlane’ does not name a type
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
