What is the value of fvc::grad(U) at boundaries?
Like Tree4Likes
  • 1 Post By EmadTandis
  • 2 Post By Zhiheng Wang
Old   May 11, 2018, 08:41
Default What is the value of fvc::grad(U) at boundaries?
Emad Tandis
EmadTandis is on a distinguished road
Hello
I am working on a elastic solver in which I need to calculate grad(U) at boundaries. I just read the code of gaussGrad.C and concluded that value of grad(U) at boundaries must be equal to patchInternalField value of grad(U), since it is zeroGradientType. But I got different experience. I need to know how grad(U) works at boundaries.
Any help will be appreciated
EmadTandis is offline   Reply With Quote
Old   May 11, 2018, 11:50
Emad Tandis
I found the reason!
gradScheme class uses a function named "correctBoundaryCondition(vf,fGrad)" using which the gGrad at boundary is corrected by snGrad at boundaries.
I hope it can be of use for fellows.
hjasak likes this.
Old   May 15, 2018, 07:44
Emad Tandis
Originally Posted by EmadTandis View Post
I found the reason!
Hello Dr Jasak
I need to calculate tangential component of grad(U) at boundaries more accurately. I guess that at boundary, it uses zero gradient condition for this component. Am I right? Is there any way to handle that or I have to develop a code by myself?
Thanks
Zhiheng Wang likes this.
Old   May 31, 2018, 06:24
Default Gradient along the boundary
Zhiheng Wang
Zhiheng Wang is on a distinguished road
Let say You got T a parameter at boundary , or volScalarField or If you want Grad on surface as surfaceScalarField
surfaceScalarField SnGrad
fvc::snGrad(T) /// Normal component of Grad T
volScalarField SnVolGrad
IOobject
"SnVolGrad",
runTime.timeName(),
mesh
mesh,
dimensionedScalar("SnVolGrad", T.dimensions()/dimLength, 0.0)
forAll(T.boundaryField(), patchi)
SnVolGrad.boundaryFieldRef()[patchi] = SnGrad.boundaryField()[patchi];
SnVolGrad.write();
volVectorField GradientY
IOobject
"GradientY",
runTime.timeName(),
mesh
fvc::grad(T)
GradientY.write();
volScalarField GradientX
IOobject
"GradientX",
runTime.timeName(),
mesh
fvc::grad(T)().component(0)
GradientX.write();
volScalarField Grad_T
IOobject
"Grad_T",
runTime.timeName(),
mesh
mesh,
dimensionedScalar("Grad_T", T.dimensions()/dimLength, 0.0)
forAll(SnVolGrad.boundaryField(),patchi)
Grad_T.boundaryFieldRef()[patchi] = GradientX.boundaryFieldRef()[patchi] + SnVolGrad.boundaryFieldRef()[patchi];
Grad_T.write();
Find suitable way any of above should work
Kummi and shiyu like this.
Zhiheng Wang is offline   Reply With Quote
Mapped vs Cyclic Boundaries in OpenFOAM arsenis OpenFOAM Running, Solving & CFD 1 February 8, 2023 21:13
[ICEM] Can I define periodic boundaries in an unstructured mesh? Aoki ANSYS Meshing & Geometry 11 September 14, 2018 01:52
2D Rotating Detonation Engine Periodic Boundaries whitet86 FLUENT 2 June 25, 2015 11:04
Setting Flow/Pressure Boundaries in Floworks Eran FloEFD, FloWorks & FloTHERM 3 August 11, 2009 04:23
periodic boundaries - flow through a net PK FLUENT 0 July 12, 2007 11:58
