February 1, 2018, 12:11 |
Access (I, J) component of a volTensorField
Gianluca
How can I access the (I, J) component of a volTensorField?
I am able to do just that with a Tensor2 such as - TensorN<scalar, 2> aa - aa(0, 1) = -1.0 - Info << aa(0, 1) << end; I then get the value -1.0 from location (0, 1) of tensor2. How do I do that for a volTensorField created with tensor2 vectors? I am trying to use each component of the volTensorField as a scalar field and perform operations on it. Thanks. |
February 1, 2018, 20:22 |
Rep Power: 15 |
Have you taken a look at this? http://foam.sourceforge.net/docs/Gui...mmersGuide.pdf Cheers, Antimony |
February 15, 2018, 07:53 |
shayan tanweer
Rep Power: 9 |
You can access the components of volTensorField like this: volScalarField scalar_1("scalar_1", mytensorfield.component(tensor::XX)); you can access other components by replacing XX with YY, ZZ, XY, YZ, ZX etc. |
field acces, tensor |
Is there a way to access the gradient limiter in Fluent ? | CFDYourself | FLUENT | 1 | February 16, 2016 05:49 |
Momentum source coefficient, cylindrical coordinates, circumferential component? | polakse | CFX | 15 | January 18, 2016 02:40 |
How can I access to a volTensorField elements? urgent!!! | adambarfi | OpenFOAM Running, Solving & CFD | 6 | May 14, 2013 16:28 |
access to velocity component in cylindrical coordinates | swati_mohanty | FLUENT | 0 | August 18, 2010 10:16 |
probes for a component of a volTensorField | titio | OpenFOAM Post-Processing | 0 | July 2, 2010 13:50 |
