Jasak's Ueqn.
Old   September 15, 2013, 22:44
Default Jasak's Ueqn.
Dongyue Li
sharonyue is on a distinguished road
Hi guys,
\begin{array}{l}
{a_p}{u_p} = \sum {{a_n}{u_n} - \nabla p,} \\
{a_p}{u_p} = \sum {{a_n}{u_n} - \int {\nabla p} dv}
\end{array}
The first one in the famous Ueqn in Jasak's thesis. but isn't it should be the below one?
Thanks in advance.
sharonyue is offline   Reply With Quote
Old   September 16, 2013, 01:41
Bernhard
Bernhard is on a distinguished road
It would help if you give a more specific reference (i.e. equation number)
Bernhard is offline   Reply With Quote
Old   September 16, 2013, 04:15
Dongyue Li
Originally Posted by sharonyue View Post
Hi guys,
\begin{array}{l}
\end{array}
Thanks in advance.
Its in his Ph.D. thesis page 145, 3.136.
I think its not correct, it should be:
{a_p}{u_p} = \sum {{a_n}{u_n} - \nabla p_f}
While it does not matter..do you think so?
Old   September 23, 2013, 10:20
Dongyue Li
my bad. \int {\nabla p} dv .................. \nabla p_f
Jasak is rite, its a kind of semi-discretised form of equation. the pressure gradient is not discretised at this stage.
interFoam's UEqn. sharonyue OpenFOAM Programming & Development 6 July 11, 2016 02:36
A question about UEqn sonicFoam lfgmarc OpenFOAM Programming & Development 6 February 1, 2015 16:49
Difference between UEqn in sonicFoam & Theory sasanghomi OpenFOAM Programming & Development 9 June 27, 2013 04:12
Adding an explicit source term in the UEqn() Anne Lincke OpenFOAM Running, Solving & CFD 0 June 25, 2013 12:19
Source term problem in UEqn of simpleFoam fisch OpenFOAM Programming & Development 1 June 17, 2011 10:57
