Making changes to the files under /opt/openfoam directory
Like Tree2Likes
  • 1 Post By Mojtaba.a
Old   August 2, 2013, 11:01
Default Making changes to the files under /opt/openfoam directory
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Hi dear Foamers,
I am trying to modify some utilities and make some small changes in them, but I do not want to make new utilities, because changes are so small.
For example I am trying to write out "Total cell numbers" while I am running "checkMesh" utility.
I don't want to make a new "checkMesh2" utility to do this. Just want to make the small change in the source file and compiling "checkMesh" utility again.
My openFOAM is installed in /opt directory.
is it possible to do this?
Best regards,
Mojtaba
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   August 2, 2013, 13:01
Nima Samkhaniani
nimasam is on a distinguished road
as opt is writing protected for user , you should be root,
i guess using sudo wmake will solve your problem, or you may want to compile it as usual, then put your binary file where present checkMesh binary file is placed
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   August 2, 2013, 15:01
Mojtaba.a's Avatar
Thank you dear Nima,
Well actually sudo wmake doesn't help, I don't know why yet. I was thinking about deleting compiled binaries of checkMesh (or maybe wclean it) and then compile my new utility with the same name (checkMesh) in FOAM_USER_APPBIN.
Your second idea is interesting.
I will report back the results.
best
Old   August 2, 2013, 15:11
Default salam
Hassan
luckycfd is on a distinguished road
Greetings Mojtaba,
following instruction:
1. cp -r $FOAM_UTILITIES/mesh/manipulation/checkMesh $FOAM_RUN/checkMesh2
2. cd $FOAM_RUN/checkMesh2
3. making your changes in the relevant source file
4.  Change your Make/files to:
                 printMeshStats.C
                 checkTopology.C
                 checkGeometry.C
                 checkMesh.C
                 EXE = $(FOAM_USER_APPBIN)/checkMesh2
5. Compile:
                  wclean
                  rm –r Make/linux*
                  wmake
Best regards,
Hassan
luckycfd is offline   Reply With Quote
Old   August 2, 2013, 15:21
Mojtaba.a's Avatar
Originally Posted by luckycfd View Post
Greetings Mojtaba,
                 printMeshStats.C
                 checkTopology.C
                 checkGeometry.C
                 checkMesh.C
5. Compile:
                  wclean
                  rm –r Make/linux*
                  wmake
Best regards,
Hassan
Thank you dear Hassan ,
Well this procedure doesn't actually replace the utility "checkMesh". I think it simply makes a new utility named "checkMesh2".
I prefer to have the old checkMesh utility with some new changes, without compiling a whole new utility named "checkMesh2".
best,
Mojtaba
Old   August 2, 2013, 15:48
Mojtaba.a's Avatar
Problem is solved,
Thank you Nima and Hassan for your suggestions.
Well actually solution was quite easy as Nimasam said.
Here is the step by step procedure:
1- Copy your desired utility into
$WM_PROJECT_USER_DIR/applications/utilities
2- modify the code and make your desired modifications.
3- Do not change *.C file name and do not change the name in /Make/files
4- run wmake
5- sudo rm /opt/openfoam---/platforms/linux64GccDPOpt/bin/utility
i.e: sudo rm /opt/openfoam---/platforms/linux64GccDPOpt/bin/checkMesh
Note: --- is your Of version
6- sudo cp $WM_PROJECT_USER_DIR/applications/utilities/utility /opt/openfoam---/platforms/linux64GccDPOpt/bin/
i.e:
sudo cp $WM_PROJECT_USER_DIR/applications/utilities/checkMesh /opt/openfoam---/platforms/linux64GccDPOpt/bin/
And you are done
Best Wishes,
Mojtaba
luckycfd likes this.
Old   September 27, 2013, 15:46
Mojtaba.a's Avatar
Hi, I want to make some little modifications to my previous post.
Here is the updated procedure:
***3- Do not change *.C file name and do not change the name in /Make/files
but instead change FOAM_APPBIN into FOAM_USER_APPBIN
4- run wmake
5- sudo rm /opt/openfoam<version>/platforms/linux64GccDPOpt/bin/utility
i.e: sudo rm /opt/openfoam221/platforms/linux64GccDPOpt/bin/checkMesh
***6- sudo cp $WM_PROJECT_USER_DIR/platforms/linux64GccDPOpt/bin/utility /opt/openfoam<version>/platforms/linux64GccDPOpt/bin/
i.e:
***sudo cp $WM_PROJECT_USER_DIR/platforms/linux64GccDPOpt/bin/checkMesh /opt/openfoam221/platforms/linux64GccDPOpt/bin/
I hope it helps a bit.
Best.
arashma likes this.
Release of a Wave Generation and Absorption Toolbox for OF ngj OpenFOAM Announcements from Other Sources 65 September 4, 2022 14:01
[waves2Foam] Waves2Foam Related Topics ngj OpenFOAM Community Contributions 660 August 20, 2018 12:39
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
OpenFoam install script Error during paraFoam installation SePe OpenFOAM Installation 10 June 19, 2010 15:15
Gerris software installation mer Main CFD Forum 2 November 12, 2005 08:50
