Error at runtime modification of a volScalField
Old   August 10, 2013, 08:34
Default Error at runtime modification of a volScalField
Daniel Leichtle
Scofield is on a distinguished road
Hi Foamers,
this is my first thread. I try to modify a volScalarField called "modifyS" during runtime of a simulation. "modifyS" is a uniform field and located in the "constant" directory of my case.
I specify this field by using following IOobject definition:
volScalarField modifyS
IOobject
"modifyS",
runTime.constant(),
mesh,
IOobject::MUST_READ_IF_MODIFIED,
IOobject::NO_WRITE
mesh
I have tried two variations:
1) I have defined this IOobject in "creativeFields.H".
2) I have tried to define this IOobject at the beginning of the time loop of my solver.
Just in case 2) the modification is read in. But I could recognize following:
In both cases, if If i change the uniform field "modifyS" during runtime, mostly the simulation goes on, but sometimes the simulation is aborted with following error:
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/BAUINFORMATIK/scheffold/OpenFOAM/scheffold-2.2.0/run/interactivity/PflegerTestModifyS/constant/modifyS at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 87.
FOAM exiting
I have compared it with a IOdictionary using "MUST_READ_IF_MODIFIED". There, the simulation never stops after making modifications in the case.
I would really appreciate if anybody knows, why the simulation sometimes is terminated when i modify a volScalField?
Best regards,
Daniel
Scofield is offline   Reply With Quote
Old   August 14, 2013, 14:02
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
when you create your field at the new time step, you are creating the new object, so it will be initialized anyway.
IOobject and regIOobject classes for this problem are under discussion here
mkraposhin is offline   Reply With Quote
runTime deji OpenFOAM 2 January 17, 2019 09:14
Probes/Sensors in runtime gabitinho OpenFOAM Post-Processing 9 August 14, 2015 12:55
Problem in3D model processing mebinitap OpenFOAM 2 December 12, 2014 04:40
runTime out of scope in functionObject Sune OpenFOAM Programming & Development 2 September 26, 2012 02:11
compressible modification of nearwall turbulence Quain Tchew Main CFD Forum 0 March 4, 2002 01:29
