June 12, 2021, 18:34 |
AMI implementation: Foundation vs. ESI
hekseli
Rep Power: 13 |
Hey,
I happened to notice that the AMI interpolation implementation differs between the Foundation and ESI versions. In particular, features presented here https://www.openfoam.com/news/main-n...20-06/numerics raised my interest whether I should try ESI version for my AMI cases. Has anyone carried out any tests regarding pros and cons between the implementation? I'm also interested in hearing the history related to separation of AMI implementations. |
July 1, 2021, 11:53 |
Erick D. Martinez
Rep Power: 5 |
I used to have some issues developing a working AMI when I was using OF7. It took me months of trying different things with my snappyHexMeshDict when the AMI examples seemed pretty straight forward. This made me look for overset meshing as an alternative, which is only available in the ESI version. Once I started using the ESI version I tried doing AMI again and it worked instantly. I went through the whole process on both ESI and OF Foundation versions and the exact same mesh generated a working AMI with ESI but it failed in OF Foundation. This was my experience at least. But from this I prefer ESI for any AMI development.
Error running AMI propeller simulation | luitzor | OpenFOAM Running, Solving & CFD | 0 | April 19, 2021 13:48 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
[swak4Foam] reconstructPar error in MRFsimpleFoam (ami apprach) using GroovyBC velocity inlet | Krao | OpenFOAM Community Contributions | 3 | August 19, 2019 05:40 |
mapField error | rvl565 | OpenFOAM Pre-Processing | 1 | September 6, 2018 16:13 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
