Adding an internal heat source for compressibleTwoPhaseEulerFoam
1 Attachment(s)
Hello dear Foamers,
I am working on the simulation of a plasma-arc-welding process and I am using the compressibleTwoPhaseEulerFoam Solver now, because it calculates the two phases (I use Argon and Air) and the temperature which I am looking for mainly. But to be exact enough I need a heat source, where the electrical current is flowing through the plasma. I would try to create a new Field "q" which would describe the increasing energy in the cells relative to the geometrical size of the cell. I found already an interesting post like this one: http://www.cfd-online.com/Forums/ope...ionfoam-2.html And this one: http://www.cfd-online.com/Forums/ope...ew-solver.html But the solver is still different. I don't have a TEqn.H. I guess I need to change the EEqn.H, but I don't know how to do it in detail. I don't know much about C++ and the "Programmers Guide" didn't enlighten me much too. My plan would be: - a readable heat source file for the Mesh [Joule/Second/m³] - accessing the volumetric size of the cells [m³] - calculating the total additional energy of the cell [Joule/Second/m³]*[m³]*[StepTimeSeconds] - subtracting it in the right part of the following equation Code:
Also I attached a slice of my 3D-model. I would appreciate your help a lot. Sincerely Kenna |
Current try
Well, so far I could create a Qp (heat flux) field with this dimensions (0, 2, -3, 0, 0, 0, 0).
I put a Qp file in the latest Time folder and put where the electric arc should be, via setFieldsDict in a cylindrical Form the value 2.14748e+09. The rest stays zero. in the createFields.H from the solver I entered this: Code:
Info<< "Reading field Qp\n" << endl; I added Qp very simple in the EEqn. Code:
fvScalarMatrix he1Eqn Code:
dimensions [0 2 -3 0 0 0 0]; Code:
dimensions [0 2 -3 0 0 0 0]; |
Could you try without the red line (and the comma at the line above after "mesh").
The temperature is rising in the right area. The pressure doesn't change as expected, because it is an open system. So far I have no further question :) |
