April 8, 2013, 13:17 |
kLowReWallFunction in OF 2.2
zurg
Rep Power: 14 |
Dear Foamers,
in the new release OF 2.2 new wall-functions are available for epsilon and K. They seem damping-functions for both Low and High Re mesh. My question are: 1) Which is the theoretical base for the equation of K in viscous sub-layer (i.e. where come from the numerical coefficients)? PHP Code:
Thanks for any advise. |
April 8, 2013, 17:57 |
Fumiya Nozaki
Rep Power: 18 |
1) You might want to read the paper(eq. (28)): http://www.os-cfd.ru/cfd_docs/wall_f..._functions.pdf 2) I think this wall function is designed for use with v2f turbulence model. I don't know whether or not it is valid to use this wall function with other turbulence models. Is there anyone familiar with this area? Hope this helps, Fumiya |
April 9, 2013, 07:32 |
#3 | |
zurg
Rep Power: 14 |
Reading the paper really helped me. |
September 11, 2013, 04:44 |
Rep Power: 13 |
I am struggling to reproduce reference results for the skin friction on a Naca airfoil (http://turbmodels.larc.nasa.gov/naca0012_val.html), so I would like to understand better the wall functions in OpenFOAM, in particular for well resolved cases.
in kLowReWallFunction, the friction velocity is computed as scalar uTau = Cmu25*sqrt(k[faceCellI]); for both the viscous and log layers, while in nutLowReWallFunction it is computed as sqrt(nuw*mag(Uw.snGrad())) In the reference paper I did not find how uTau should be computed. Are the two approaches consistent? If not, do you know how it should be done? Should the wall shear stress be computed from uTau or, as it is done in wallShearStress from (nu + nut)*grad(U)? Thank you |
low reynolds, near wall functions, turbulence |
Display Modes | |
Exit Velocity of a Mach 2.2 Jet | oe_jet | Main CFD Forum | 0 | June 24, 2010 15:36 |
Gambit 2.2 | Sal | FLUENT | 0 | July 12, 2007 22:14 |
The font size of Gambit 2.2 GUI menu and Pad | David | FLUENT | 3 | March 6, 2007 16:21 |
Gambit 2.0 and 2.2 STAIRSTEP meshing difference | Paweł | FLUENT | 0 | October 15, 2006 10:34 |
exceed for gambit 2.2 | steve | FLUENT | 4 | July 26, 2005 09:09 |
