-   OpenFOAM Programming & Development (https://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   developing doc (https://www.cfd-online.com/Forums/openfoam-programming-development/123382-developing-doc.html)
cctv September 11, 2013 10:29
developing doc
Hi
I am wondering if openfoam1.6-ext and online doc cpp like the link below?
http://www.openfoam.org/docs/cpp/
Thanks
Bernhard September 11, 2013 10:47
I am not aware of one, but with Doxygen you can generate it yourself.
luckycfd September 11, 2013 11:42
How can I use the Doxygen in my pc without internet?
thanks,
Hassan
cctv September 11, 2013 11:47
well,if the app generated by Doxygen would explain the usage like below?:
Detailed Description
template<class Type>
class Foam::fixedGradientFvPatchField< Type >
This boundary condition supplies a fixed gradient condition, such that the patch values are calculated using:
http://foam.sourceforge.net/docs/cpp/form_17.png
where
http://foam.sourceforge.net/docs/cpp/form_18.png = patch values http://foam.sourceforge.net/docs/cpp/form_19.png = internal field values http://foam.sourceforge.net/docs/cpp/form_20.png = gradient (user-specified) http://foam.sourceforge.net/docs/cpp/form_21.png = inverse distance from patch face centre to cell centre
Bernhard September 12, 2013 01:34
I don't know where you found it, but the linked doc cpp is created using Doxygen. That is just a tool that generates this documentation based on the source code, so it work on any C++ source code.
@lcukycfd: As soon as you downloaded and installed Doxygen, you can use it offline.
Chris Lucas September 12, 2013 03:09
a user-driven documentation project for OpenFOAM is the CoCoon project.
http://www.cfd-online.com/Forums/ope...echnology.html
Christian
cctv September 12, 2013 06:32
Originally Posted by Chris Lucas (Post 451266)
Christian
Hi
I think this project is newly created, isn't it? I am not sure if it support extention version of OpenFOAM. I am just wondering if there exist one website supporting openfoam-1.6-ext similar to the link I provided above.
Thanks
Yu
Chris Lucas September 12, 2013 06:43
it supports OpenFOAM ext. The same guys are behind both projects
Regards,
Christian
luckycfd September 13, 2013 01:39
@Bernhard: thanks, it works good.
Regards,
Hassan
