Home > Forums > OpenFOAM Programming & Development
runtime sample plan: how to get gradP
Old   September 16, 2013, 05:22
Default runtime sample plan: how to get gradP
Marcel Vonlanthen
Sylv is on a distinguished road
Dear Foamer,
for a LES run, I would like to extract sample planes of gradP during runtime. For this, I'm using this tool:http://www.openfoam.com/features/run...processing.php. It works perfectly for U or p, but not for gradP, as this variable doesn't exist at runtime. So until now I simply modified pimpleFoam and add the following lines:
volVectorField gradP
        IOobject
            "gradP",
            runTime.timeName(),
            mesh,
            IOobject::READ_IF_PRESENT,
            IOobject::AUTO_WRITE
        fvc::grad(p)
This trick works fine, I can access gradP with the sampling tool during runtime. But as it's not very flexible, I'm wondering if I can use a codeStream in the sample tool? I try the following code, but it did not work. In fact, I don't know the type which codestream should return. a List<word> maybe?
    type                      surfaces;
    functionObjectLibs        ("libsampling.so");
    outputControl             timeStep;
    outputInterval            1;
    surfaceFormat             vtk;
    fields                    #codeStream
        code
                IOobject
                    "gradP",
                    runTime.timeName(),
                    mesh,
                fvc::grad(p)
            const wordList sampleFields = ("gradP"); //is that correct?
            os << sampleFields;//is that correct?
    interpolationScheme       cellPointFace;
Cheers,
Marcel
Sylv is offline   Reply With Quote
Old   September 16, 2013, 05:48
Bernhard
Bernhard is on a distinguished road
What do you mean with: "it doesn't work"
I think you need to use a coded functionobject to create the field, and then use it in the sampling functionobject.
Bernhard is offline   Reply With Quote
Old   September 16, 2013, 08:21
Marcel Vonlanthen
Hi Berhnard,
Thanks for your post, it gave me new ideas
As example, I use OF221 and the LES tutorial case "pitzDaily", located in the foam tutorials folder: $FOAM_TUTORIALS/incompressible/pisoFoam/les/pitzDaily
Replace the controlDict by this one:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     pisoFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         0.1;
deltaT          1e-05;
writeControl    timeStep;
writeInterval   100;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
    gradP
        functionObjectLibs ("libutilityFunctionObjects.so");
        type coded;
        redirectType average;
        code
            const volScalarField& p = mesh().lookupObject<volScalarField>("p");
            const volVectorField gradP = fvc::grad(p);
            Info << "gradP[0] =" << gradP[0] << endl;
            Info << "gradP[5] =" << gradP[5] << endl;
    surfaceSampling
        type surfaces;
        enabled             true;
        interpolationScheme cellPoint;
        surfaceFormat       foamFile;
        fields              (p gradP);
        surfaces
            plane01
                type                cuttingPlane;
                planeType           pointAndNormal;
                pointAndNormalDict
                    basePoint       (0.001 0.001 0);
                    normalVector    (0 1 0);
                interpolate         true;
Then, run pisoFoam for a few timestep. The codeStream Is compiled without errors and writes out the values of gradP[0] and gradP[5]. So, now gardP exists during the run. Nevertheless, the sample tool does not create a cutting plane from gradP. So I remplace the controlDict by this one:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
startTime       0;
stopAt          endTime;
endTime         0.1;
deltaT          1e-05;
writeInterval   100;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
timeFormat      general;
timePrecision   6;
functions
    gradP
        type coded;
        code
                IOobject
                    "gradP",
                    runTime.timeName(),
                    mesh,
                fvc::grad(p)
    surfaceSampling
        type surfaces;
        enabled             true;
        fields              (p gradP);
        surfaces
            plane01
                type                cuttingPlane;
                pointAndNormalDict
                interpolate         true;
But this codeStream does not compile properly: the object "runTime" of class "Time" does not not exist. I tried to access the existing "runTime" with a kind of lookup function (like for p), but it does not works.
How could I generate the volVectorField gradP, which can be used by the sample tool?
Old   September 16, 2013, 08:26
Bernhard
I think you can access the runTime by something (untested!) like
const Time& runTime = mesh.time()
Old   September 17, 2013, 03:31
Marcel Vonlanthen
Hi Foamer,
So Bernhard, I add your line of code:
const Time& runTime = mesh().time();
which gave me access to the runTime object, so I can call runTime.timeName() for the IOobject. But I still missing the "mesh" object of class "fvMesh". So I tried somthing like:
const fvMesh& mesh = mesh().lookup("mesh");
or
const fvMesh& mesh = mesh().Mesh
But both compile with error. So I tried this (copy paste from the solver...):
fvMesh mesh
                IOobject
                    fvMesh::defaultRegion,
                    runTime.timeName(),
                    runTime,
                    IOobject::MUST_READ
Which compiles without error, but the sample tool cannot generate the gardP slice. It's not really a surprise, because I'm recreating the mesh object without using the existing one created by the solver. So If somebody knows how to access by reference to the mesh object, that could be cool ;-)...
Old   September 17, 2013, 03:35
Bernhard
Isn't mesh() itself already a reference to the mesh that you need?
Thread Tools
Trackbacks are On
Problem in3D model processing mebinitap OpenFOAM 2 December 12, 2014 05:40
How to sample (with interpolation) at runtime ole OpenFOAM Programming & Development 4 December 14, 2010 13:57
How to sample ptot at runtime pad OpenFOAM Post-Processing 0 August 26, 2010 07:45
heat conducting in a solid domain Rogerio Fernandes Brito FLUENT 0 March 18, 2008 18:25
heat conducting in a solid domain Rogerio Fernandes Brito CFX 0 March 18, 2008 18:20
