Using MULES to solve transport equation with sharp interface |
September 16, 2013, 12:47 |
A. Bernath
I'm modelling the curing behavior of a thermosetting polymer which is injected into a mold. For this, I took the compressibleInterFoam solver as a starting point and extended it in order to calculate the increase in degree of cure. This then is added to the current degree of cure which has to be convected with the flow field. At this point, I'm facing the problem of numerical diffusion during the filling step. Due to this I get a degree of cure greater than zero in areas where there is no resin at all. Up to now I tried limitedLinear01 and currently I'm running a test case with vanLeer. Besides this, I'm curious if it is possible to use the MULES solver for this specific problem. I tried some implementations but most of them crashed the solver in the second time step and the other led to unphysical values. Long story short: Is it even possible to convect a scalar through a domain by coupling its flux field to that of alpha by using MULES? This should give an interface as sharp as that of alpha or not? Thanks in advance! Alex Last edited by derkermit; September 17, 2013 at 05:07. |
February 26, 2014, 23:03 |
zhanglei
Rep Power: 12 |
Hi, Derkermit!
I also tried to simulate injection molding filling process, and encountered similar problems. The results(shown in the picture) of the unsteady convection equation(VOF model) of scalar field alpha is disappointing. I don't know if my questions are similar to yours? Looking forward to your reply |
February 27, 2014, 05:09 |
A. Bernath
Hey,
I think your problem is somehow different. The implementation of the alpha field already uses MULES to maintain a sharp interface. This should work (more or less) out of the box. Which solver and OF version are you using and how does your fvSchemes look like? Back to topic: I managed to solve the transport equation for the degree of cure with MULES. I had to adapt the alphaEqnsSubCycle.H file of compressibleInterFoam (OF221) and extended it by this: Code:
... else { #include "alphaEqns.H" } // Here begins the new part volScalarField::DimensionedInternalField SpCure ( IOobject ( "SpCure", runTime.timeName(), mesh ), mesh, dimensionedScalar("SpCure", cureSource.dimensions(), 0.0) ); volScalarField::DimensionedInternalField SuCure ( IOobject ( "SuCure", runTime.timeName(), mesh ), // Divergence term is handled explicitly to be // consistent with the explicit transport solution divU*cure ); forAll(cureSource, celli) { SuCure[celli] += cureSource[celli]*alpha1[celli]; } surfaceScalarField phiCure ( fvc::flux ( phi, cure, alphaScheme ) + fvc::flux ( -fvc::flux(-phir, alpha2, alpharScheme), cure, alpharScheme ) ); MULES::explicitSolve ( geometricOneField(), cure, phiCure, SpCure, SuCure ); Info<< "Cure = " << cure.weightedAverage(mesh.V()).value() << " Max(cure) = " << max(cure).value() << " Min(cure) = " << min(cure).value() << endl; |
February 27, 2014, 06:37 |
zhanglei
Rep Power: 12 |
My OF is the 1.6-ext version, and divschemes {div(phi,alpha) gauss vanleer; div(phirb,alpha) gauss intefaceCompression} .
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
udf and uds for transport equation | m003020002 | Fluent UDF and Scheme Programming | 1 | September 15, 2015 01:02 |
add source term to transport equation | m003020002 | Fluent UDF and Scheme Programming | 0 | September 10, 2013 03:09 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
