Home > Forums > OpenFOAM Programming & Development
Creating a New Turbulence Model- Symbol Lookup Error
Old   September 24, 2013, 21:03
Default Creating a New Turbulence Model- Symbol Lookup Error
AA29 is on a distinguished road
Hello All,
I compiled a new turbulence model in OpenFoam 2.2.1.To use that turbulence model, i created a new solver just to use the new turbulence library.Please note that i did not modify the solver or anything, i just recompiled it to use my turbulence libraries. It works fine.
But the weird thing is all the other standard solvers have stopped working,a nd i get the following error whichever solver I try to run:
Create time
Create mesh for time = 0
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone rotatingZone
PIMPLE: Operating solver in PISO mode
Reading thermophysical properties
Selecting thermodynamics package
type hePsiThermo;
mixture pureMixture;
transport sutherland;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
AMI: Creating addressing and weights between 10944 source faces and 10944 target faces
AMI: Patch source weights min/max/average = 1, 1.00185, 1
AMI: Patch target weights min/max/average = 1, 1.00185, 1
Reading field U
Creating turbulence model
rhoPimpleDyMFoam: symbol lookup error: rhoPimpleDyMFoam: undefined symbol: _ZN4Foam12compressible15turbulenceModel3NewERKNS_1 4GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEER KNS2_INS_6VectorIdEES3_S4_EERKNS2_IdNS_13fvsPatchF ieldENS_11surfaceMeshEEERKNS_11fluidThermoERKNS_4w ord.
I understand something went wrong while I compiled the new turbulence model , but I am not able to identify the problem.
Anybody else had this kind of problem?
Any help will be appreciated.
Thanks and Regards.
AA29 is offline   Reply With Quote
Old   September 25, 2013, 10:23
Matt Laurita
mlaurita is on a distinguished road
Looks kind of like a linking issue. But it's a little hard to tell without knowing how your new turbulence model fits with the existing ones, which libraries are linked to your new solver, etc. Maybe you could share your Make/options files for the solver and the library?
mlaurita is offline   Reply With Quote
Old   September 25, 2013, 20:02
Hi Matt,
Thanks for the response, and sorry for the late reply. The options file for the compressible/LES library is as follows :
EXE_INC = \
-I$(WM_PROJECT_USER_DIR)/src/turbulenceModels \
-I$(WM_PROJECT_USER_DIR)/src/turbulenceModels/compressible/turbulenceModel/lnInclude \
-I$(LIB_SRC)/turbulenceModels/LES/LESdeltas/lnInclude \
-I$(LIB_SRC)/turbulenceModels/LES/LESfilters/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude \
-I$(LIB_SRC)/finiteVolume/lnInclude
LIB_LIBS = \
$(FOAM_USER_LIBBIN)/libcompressibleTurbulenceModel.so \
-lLESdeltas \
-lLESfilters \
-lfiniteVolume \
-lmeshTools
And the same for the solver is :
EXE_INC = \
-I$(WM_PROJECT_USER_DIR)/applications/solvers/my_XiFoam \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/fvOptions/lnInclude \
-I$(LIB_SRC)/sampling/lnInclude \
-I$(LIB_SRC)/engine/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \
-I$(WM_PROJECT_USER_DIR)/src/turbulenceModels/compressible/turbulenceModel \
-I$(LIB_SRC)/thermophysicalModels/laminarFlameSpeed/lnInclude
EXE_LIBS = \
-lfiniteVolume \
-lfvOptions \
-lsampling \
-lmeshTools \
-lengine \
$(FOAM_USER_LIBBIN)/libcompressibleRASModels.so \
$(FOAM_USER_LIBBIN)/libcompressibleLESModels.so \
-lfluidThermophysicalModels \
-lreactionThermophysicalModels \
-lspecie \
-llaminarFlameSpeedModels
Hope this is what you required.
Thanks
Thread Tools
Trackbacks are On
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 10:40
compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 2 August 30, 2013 07:42
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
