Home > Forums > OpenFOAM Programming & Development
Calling twophasemixture member function
Like Tree2Likes
  • 2 Post By styleworker
Old   September 25, 2013, 12:43
Default Calling twophasemixture member function
styleworker is on a distinguished road
Hello foamers!
I'm quite familiar with using OpenFoam, but now I want to go further and learn more about programming in OF. At the moment I'm playing around with MRconjugateHeatFoam. I tried to extend it to a two phase flow solver, but I'm not able to call the twoPhaseProperties function.
This part of the boundary function is of interest:
HTML Code:
Foam::tmp<Foam::scalarField>
Foam::regionCoupleTemperatureFvPatchScalarField::flux() const
    const dimensionedScalar& rho1 = twoPhaseProperties.rho1();
    const fvPatchScalarField& T = *this;
    return rho1.value()*T.snGrad();
At the beginning of the file, the header file twoPhaseMixture.H is included. Somehow I'm getting the error: »twoPhaseProperties« is not defined
Did I included the wrong header file?
styleworker is offline   Reply With Quote
Old   September 25, 2013, 20:01
Dongyue Li
sharonyue is on a distinguished road
I think you should construct transportProperties like this :
incompressibleTwoPhaseMixture twoPhaseProperties(U, phi);
If I am wrong correct me pls.
sharonyue is offline   Reply With Quote
Old   September 26, 2013, 08:43
Thank you for your reply. Indeed you're right.
It seems incompressibleTwoPhaseMixture was renamed to twoPhaseMixture in OF. In my case (OF-2.2.0) it should be:
twoPhaseMixture twoPhaseProperties(U, phi,"alpha1");
Certainly the U-, and phi-field has to be defined/read:
const volVectorField& U = db().lookupObject<volVectorField>("U");
const surfaceScalarField& phi = db().lookupObject<surfaceScalarField>("phi");
The complete code-snippet:
sharonyue and ahmmedshakil like this.
Thread Tools
Trackbacks are On
error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Native Meshers: blockMesh 2 March 14, 2012 10:56
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 09:53
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
LibvtkFoamso fred OpenFOAM Paraview & paraFoam 2 November 18, 2005 20:01
