-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Diffusion term in OpenFOAM (http://www.cfd-online.com/Forums/openfoam-programming-development/124403-diffusion-term-openfoam.html)
MatzeS October 4, 2013 08:00
checking the term turbulence->divDevReff(U) I came up with the following question:
The diffusion term for incompressible flows should look somehow like this (here, I ignored the viscosity):
fvc::div(fvc::grad(U)+fvc::grad(U)().T())
And this can be transformed to this:
fvc::laplacian(U)
But when I implement that into OpenFOAM, those terms give different results. I assume it is connected to the discretization schemes, but even when I use linear for all schemes, it gives me different results.
So, what do I do wrong? What do I miss? Is it because of wall-functions or boundary conditions?
Any comment is appreciated...
Regards,
Matze
jherb February 12, 2014 10:23
I think this wiki page might explain what is going on here:
http://openfoamwiki.net/index.php/Bu...DevReff.28U.29
Also have a look at this thread (the difference between compressible and incompressible models goes away if the continuity equation is fulfilled after convergence of the solution):
http://www.cfd-online.com/Forums/ope...ivdevreff.html
Bernhard February 12, 2014 10:43
fvc::laplacian(U)
Regards,
Matze
You ignored viscosity in your derivation. The turbulent viscosity is not constant, so you can't pull it through the differential.
MatzeS February 12, 2014 10:55
thank you for your reply, it was very helpful!
Regards,
Matze
