-   OpenFOAM Programming & Development (https://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Changing Polynomial Properties of species from 8 to 16 coefficients (https://www.cfd-online.com/Forums/openfoam-programming-development/124627-changing-polynomial-properties-species-8-16-coefficients.html)
Kenna October 9, 2013 11:25
P { margin-bottom: 0.21cm; } I have a case in which I need the implement thermophysical properties for a wide temperature range of fluids from 300 K to 30000 K. I got the data but have trouble to let OpenFoam use them.
My first choice for this problem would be copying the existing library about polynomial functions for the thermophysicalProperties-File and make out of 8 coefficients 16. I made a custom solver already which is directed to the copied libary and the solver works with it.
I changed in the make/options file this:
EXE_INC = \
    -I$(WM_PROJECT_DIR)/src/thermophysicalModels/basic/lnInclude \
by this
EXE_INC = \
    -I$(WM_PROJECT_USER_DIR)/src/thermophysicalModels/basic/lnInclude \
Is it enough to change in all relevant files the 8 to a 16? Relevant files might be for example:
thermophysicalModels/specie/include/thermoPhysicsTyes.H //i.e icoPolynomial<specie, 16>,
For icoPolynomial:
src/thermophysicalModels/specie/equationOfState/icoPolynomial/icoPolynomial.C
src/thermophysicalModels/specie/equationOfState/icoPolynomial/icoPolynomial.H //i.e. PolySize=16
src/thermophysicalModels/specie/equationOfState/icoPolynomial/icoPolynomialI.H
And the same files for:
thermo/hPolynomial
transport/polynomial
I tried to change only the icoPolynomial part. Used ./Allwmake on /src/thermophysicalModels
and a got a Error message from the terminal.
kennametal@kennametal-Precision-WorkStation-T3500:~/OpenFOAM/kennametal-2.2.0/src/thermophysicalModels$ ./Allwmake
 + wmake libso specie
 Making dependency list for source file reaction/reactions/makeLangmuirHinshelwoodReactions.C
 Making dependency list for source file reaction/reactions/makeReactions.C
 SOURCE=reaction/reactions/makeReactions.C ;  g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100  -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude  -fPIC -c $SOURCE -o Make/linuxGccDPOpt/makeReactions.o
 SOURCE=reaction/reactions/makeLangmuirHinshelwoodReactions.C ;  g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100  -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude  -fPIC -c $SOURCE -o Make/linuxGccDPOpt/makeLangmuirHinshelwoodReactions.o
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libspecie.so: Permission denied
 collect2: ld gab 1 als Ende-Status zurück
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libspecie.so] Fehler 1
 + wmake libso solidSpecie
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libsolidSpecie.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libsolidSpecie.so] Fehler 1
 + wmake libso thermophysicalFunctions
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libthermophysicalFunctions.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libthermophysicalFunctions.so] Fehler 1
 + ./properties/Allwmake
 + wmake libso liquidProperties
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libliquidProperties.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libliquidProperties.so] Fehler 1
 + wmake libso liquidMixtureProperties
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libliquidMixtureProperties.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libliquidMixtureProperties.so] Fehler 1
 + wmake libso solidProperties
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libsolidProperties.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libsolidProperties.so] Fehler 1
 + wmake libso solidMixtureProperties
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libsolidMixtureProperties.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libsolidMixtureProperties.so] Fehler 1
 + wmake libso basic
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libfluidThermophysicalModels.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libfluidThermophysicalModels.so] Fehler 1
 + wmake libso reactionThermo
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libreactionThermophysicalModels.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libreactionThermophysicalModels.so] Fehler 1
 + wmake libso laminarFlameSpeed
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/liblaminarFlameSpeedModels.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/liblaminarFlameSpeedModels.so] Fehler 1
 + wmake libso chemistryModel
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libchemistryModel.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libchemistryModel.so] Fehler 1
 + wmake libso barotropicCompressibilityModel
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libbarotropicCompressibilityModel.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libbarotropicCompressibilityModel.so] Fehler 1
 + wmake libso SLGThermo
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libSLGThermo.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libSLGThermo.so] Fehler 1
 + wmake libso solidThermo
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libsolidThermo.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libsolidThermo.so] Fehler 1
 + wmake libso solidChemistryModel
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libsolidChemistryModel.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libsolidChemistryModel.so] Fehler 1
 + wmake libso radiationModels
 /usr/bin/ld: cannot open output file /opt/openfoam220/platforms/linuxGccDPOpt/lib/libradiationModels.so: Permission denied
 make: *** [/opt/openfoam220/platforms/linuxGccDPOpt/lib/libradiationModels.so] Fehler 1
In short I think the first problem starts here
I guess I need to adjust somewhere an other option file or an #include command.
I don't know any further. I would appreciate your help.
Thanks
Kenna
Also this post was helpful to me so far:
http://www.cfd-online.com/Forums/ope...olynomial.html
I am using OpenFOAM 2.2.0
and especially the solver compressibleTwoPhasesEulerFoam
Kenna November 20, 2013 03:44
So, after some time I tried it again and it works. Maybe the problem was something else in OpenFOAM.
I tested it with the PolynomialTransport.H
I changed the PolySize=8 to PolySize=16
In the thermoPhysicsTypes.H
I changed in the one specific thermoType description with a polynomial Transport the last 8 to a 16.
I tested a case with compressibleTwoPhaseEulerFoam. The Error Messages demandes 16 coefficients. I put zeros at the mueCoeffs till there were 16 numbers. And it calculated.
I also guess it calculates correct. But I didn't check this with other Cases jet.
