Attempt to implement the Chorin Projection Method
Old   October 26, 2013, 06:46
Default Attempt to implement the Chorin Projection Method
Martin Goddard
McFly is on a distinguished road
As above, I'm attempting to implement the Chorin Projection Method in OpenFOAM. This is my first time playing with solvers, I'm taking most of my information from the paper, "On the Implementation of Low-Dissipative, Fractional Step Methods for Transient Flows Using OpenFOAM" V Vuorinen, J.-P Keskinen, C Duwig, O Kaario, M Larmi, B J Boersma.
I have code that compiles but doesn't work. It blows up. Although I can see the results are clearly wrong in paraFoam, the equations seem sound based on the above paper and other reading.
Can you help me find what I'm missing? I've been searching for days and haven't found a complete implementation of the code to look at.
Cheers,
Marty
    phi = fvc::interpolate(U) & mesh.Sf();
    dU = (-fvc::div(phi)*U + nu*fvc::laplacian(U))*runTime.deltaT();
    U = U + dU;
    U.correctBoundaryConditions();
    solve(fvm::laplacian(p) == fvc::div(phi)/runTime.deltaT());
    U = U - runTime.deltaT()*fvc::grad(p);
McFly is offline   Reply With Quote
chorin, openfoam, projection method
Projection Methods Petrov Main CFD Forum 2 June 10, 2011 09:50
Chorin's Projection Method for Finite Volume Scott2 Main CFD Forum 1 August 16, 2010 20:24
Inner non linear iterations and Newton method misabel Main CFD Forum 3 March 11, 2010 11:19
projection method ilker basol Main CFD Forum 8 January 28, 2003 14:51
How to implement LU-SGS method Y.M. Wu Main CFD Forum 3 April 28, 1999 17:59
