October 29, 2013, 10:38 |
Adding two Energy Equations to Porous Solver
Faraj
Hello everyone,
I want to simulate porous media with solid heat transfer. I am going to add "addTwoEquationsEnthalpy" to hEqn.h fvScalarMatrix hEqn ( fvm::div(phi, h) - fvm::Sp(fvc::div(phi), h) - fvm::laplacian(turbulence->alphaEff(), h) == - fvc::div(phi, 0.5*magSqr(U), "div(phi,K)") ); pZones.addTwoEquationsEnthalpySource(thermo, gamma, ts, hEqn); hEqn.relax(); hEqn.solve(); thermo.correct(); Apart from it I should add tsEqn.h equation somewhere in solver folder "I guess so" fvScalarMatrix tsEqn ( -fvm::laplacian(kappa,ts) ); pZones.addTwoEquationsTsSource(thermo, gamma, ts, tsEqn); tsEqn.relax(); tsEqn.solve();} Here "kappa" is convection constant and "ts" is temperature of solid. I just don't know the procedure of adding this equation to the solver. If you could help me, that would be very nice. Thank you. |
October 30, 2013, 16:19 |
Cyprien
Rep Power: 18 |
Is your simulation domain only a porous medium ? In that case, I suggest you to program your own solver. You will get what you are doing under control !
Here is a full tutorial to program a 2 temperatures heat transfer solver in porous media (from slide #60) https://www.imft.fr/IMG/pdf/INITIATI...OME_1v3-05.pdf Everything is in French (I prepare an english version.. but not for now) but there is all the snippets and you could easily understand what you have to code. Regards, Cyp |
December 3, 2013, 05:20 |
Faraj
This is perfrect, Thank you very much. I already started to modification of the solvers.
My simulation domain is partially (20 %) porous medium. |
Energy based steady state solver. | atareen64 | OpenFOAM Running, Solving & CFD | 6 | May 6, 2011 11:21 |
Maths problem when deriving conservation of energy equations. | Demonwolf | Main CFD Forum | 1 | June 15, 2009 14:21 |
free " ordinary differential equations solver" | ztdep | Main CFD Forum | 2 | March 21, 2006 01:58 |
Porous media convection UDS equations | cp | FLUENT | 1 | September 19, 2003 19:53 |
Navier-stokes equations and iterative solver?? | wuliang | Main CFD Forum | 2 | January 13, 2003 22:28 |
