-   OpenFOAM Programming & Development (https://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   How do I alter inletOutletFvPatchField to use a refValue calculated w/in the code? (https://www.cfd-online.com/Forums/openfoam-programming-development/125990-how-do-i-alter-inletoutletfvpatchfield-use-refvalue-calculated-w-code.html)
chyczewski November 5, 2013 15:37
I am solving the governing equation within a loop as follows:
for (int m=0; m<mMax; ++m)
  for (int n = 0; n<nMax; ++n)
      (Calculate Smn and phimn and extract Amn from a global A)
      scalar Aeqmn = Aeq[m][n];
      solve(fvm::ddt(Amn)+fvm::div(phimn,Amn)==SMN);
      (Update global A with updated Amn)
I copied inletOutletFvPatchField to a new waveInletOutletFvPatchField and have it linked to the code. However, I need some guidance on how to modify it so that, at the inflow boundary cells, instead of applying a reference value read from an input file, it applies a Aeqmn (defined above the call to solve). Any help or reference to similar examples would be appreciated. Thanks.
