Home > Forums > OpenFOAM Programming & Development
Error In patch type 'genericPatch' not type 'directMappedPatchBase'
Old   November 13, 2013, 22:49
Default Error In patch type 'genericPatch' not type 'directMappedPatchBase'
hua1015's Avatar
Hua
hua1015 is on a distinguished road
Hi, foamers,
I want to create a 2D simulation just like the Openfoam-1.6-ext chtMultiRegionFoam using mixed coupled boundary condition.
After compiled successfully, but fail in my case.
here is the error:
--> FOAM FATAL ERROR:
for patch UP of field B in file "/home/junhuapan/OF_tutorials/i_c_mhd/0/fluid/B"
From function MixedBCoupledFvPatchScalarField::MixedBCoupledFvPa tchScalarField
const fvPatch& p,
const DimensionedField<scalar, volMesh>& iF,
const dictionary& dict
in file coupledFvPatchFields/regionCoupleB/MixedBCoupledFvPatchScalarField.C at line 91.
here is my MixedBCoupledFvPatchScalar.C
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration |
\\ / A nd | Copyright held by original author
\\/ M anipulation |
License
This file is part of OpenFOAM.
OpenFOAM is free software; you can redistribute it and/or modify it
under the terms of the GNU General Public License as published by the
Free Software Foundation; either version 2 of the License, or (at your
option) any later version.
OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
for more details.
You should have received a copy of the GNU General Public License
along with OpenFOAM; if not, write to the Free Software Foundation,
Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include "MixedBCoupledFvPatchScalarField.H"
#include "addToRunTimeSelectionTable.H"
#include "fvPatchFieldMapper.H"
#include "volFields.H"
#include "directMappedPatchBase.H"
// * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * //
Foam::MixedBCoupledFvPatchScalarField::
const fvPatch& p,
mixedFvPatchScalarField(p, iF),
neighbourFieldName_("undefined-neighbourFieldName")
this->refValue() = 0.0;
this->refGrad() = 0.0;
this->valueFraction() = 1.0;
const MixedBCoupledFvPatchScalarField& ptf,
const fvPatch& p,
const fvPatchFieldMapper& mapper
mixedFvPatchScalarField(ptf, p, iF, mapper),
neighbourFieldName_(ptf.neighbourFieldName_)
const fvPatch& p,
neighbourFieldName_(dict.lookup("neighbourFieldNam e"))
if (!isA<directMappedPatchBase>(this->patch().patch()))
FatalErrorIn
"MixedBCoupledFvPatchScalarField::"
"MixedBCoupledFvPatchScalarField\n"
"(\n"
" const fvPatch& p,\n"
" const DimensionedField<scalar, volMesh>& iF,\n"
" const dictionary& dict\n"
")\n"
) << "\n patch type '" << p.type()
<< "' not type '" << directMappedPatchBase::typeName << "'"
<< "\n for patch " << p.name()
<< " of field " << dimensionedInternalField().name()
<< " in file " << dimensionedInternalField().objectPath()
<< exit(FatalError);
fvPatchScalarField:perator=(scalarField("value", dict, p.size()));
if (dict.found("refValue"))
// Full restart
refValue() = scalarField("refValue", dict, p.size());
refGrad() = scalarField("refGradient", dict, p.size());
valueFraction() = scalarField("valueFraction", dict, p.size());
else
// Start from user entered data. Assume fixedValue.
refValue() = *this;
refGrad() = 0.0;
const MixedBCoupledFvPatchScalarField& wtcsf,
mixedFvPatchScalarField(wtcsf, iF),
neighbourFieldName_(wtcsf.neighbourFieldName_)
// * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * //
void Foam::MixedBCoupledFvPatchScalarField::updateCoeff s()
if (updated())
return;
// Get the coupling information from the directMappedPatchBase
const directMappedPatchBase& mpp = refCast<const directMappedPatchBase>
patch().patch()
const polyMesh& nbrMesh = mpp.sampleMesh();
const fvPatch& nbrPatch = refCast<const fvMesh>
nbrMesh
).boundary()[mpp.samplePolyPatch().index()];
// Force recalculation of mapping and schedule
const mapDistribute& distMap = mpp.map();
tmp<scalarField> intFld = patchInternalField();
const MixedBCoupledFvPatchScalarField& nbrField =
refCast<const MixedBCoupledFvPatchScalarField>
nbrPatch.lookupPatchField<volScalarField, scalar>
neighbourFieldName_
// Swap to obtain full local values of neighbour internal field
scalarField nbrIntFld = nbrField.patchInternalField();
mapDistribute::distribute
Pstream::defaultCommsType,
distMap.schedule(),
distMap.constructSize(),
distMap.subMap(), // what to send
distMap.constructMap(), // what to receive
nbrIntFld
// Swap to obtain full local values of neighbour K*delta
const dictionary& transportProperties =
nbrField.db().lookupObject<IOdictionary>("transpor tProperties");
dimensionedScalar MuZegma1(transportProperties.lookup("MuZegma"));
scalarField nbrKDelta = MuZegma1.value()*nbrPatch.deltaCoeffs();
distMap.schedule(),
nbrKDelta
// const objectRegistry& db2=ownPatch.thisDb();
const dictionary& transportProperties1 =
db().lookupObject<IOdictionary>("transportProperti es");
dimensionedScalar MuZegma2(transportProperties1.lookup("MuZegma"));
tmp<scalarField> myKDelta = MuZegma2.value()*patch().deltaCoeffs();
// Both sides agree on
// - B : (myKDelta*fld + nbrKDelta*nbrFld)/(myKDelta+nbrKDelta)
// - gradient : (B-fld)*delta
// We've got a degree of freedom in how to implement this in a mixed bc.
// (what gradient, what fixedValue and mixing coefficient)
// Two reasonable choices:
// 1. specify above temperature on one side (preferentially the high side)
// and above gradient on the other. So this will switch between pure
// fixedvalue and pure fixedgradient
// 2. specify gradient and temperature such that the equations are the
// same on both sides. This leads to the choice of
// - refGradient = zero gradient
// - refValue = neighbour value
// - mixFraction = nbrKDelta / (nbrKDelta + myKDelta())
this->refValue() = nbrIntFld;
this->valueFraction() = nbrKDelta / (nbrKDelta + myKDelta());
mixedFvPatchScalarField::updateCoeffs();
here is my B in '0' of fluid domain:
FoamFile
version 2.0;
format ascii;
class volScalarField;
object B;
dimensions [1 0 -2 0 0 -1 0];
internalField uniform 5;
boundaryField
L
type fixedValue;
value uniform 0;
R
type fixedValue;
value uniform 0;
UP
type MixedBCoupled;
neighbourRegionName u_solid;
neighbourPatchName U_D;
neighbourFieldName B;
value $internalField;
D
type MixedBCoupled;
neighbourRegionName d_solid;
neighbourPatchName D_U;
frontAndBackPlanes
type empty;
Thanks for any suggestions.
hua1015 is offline   Reply With Quote
Thread Tools
Trackbacks are On
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 108 June 9, 2015 08:13
second order schemes marine OpenFOAM 66 October 26, 2014 12:10
Fluent msh and cyclic boundary cfdengineering OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 48 January 25, 2013 04:28
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 12:23
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
