Center of Mass / volume
Old   November 14, 2013, 10:26
Default Center of Mass / volume
Aurelien Thinat
Aurelien Thinat is on a distinguished road
Hi everyone,
I'm trying to add the calculation of the center of mass in the solver InterFoam. I wrote in interFoam.C :
vector CoM = sum(mesh.V()*(alpha1*rho1 + (1-alpha1)*rho2)*mesh.C().internalField())/sum(mesh.V()*(alpha1*rho1+(1-alpha1)*rho2));
So far it compiles correctly but the results are wrong. So I added another vector relative to the center of volume :
vector CoV = sum(mesh.V()*mesh.C().internalField())/sum(mesh.V());
And now it doesn't compile anymore.
I can't see the probleme. If the first line compile, the second should too. Does anyone of you have any idea ?
EDIT :
After some tests it seems the problem is coming from "mesh.C().internalField()". As soon as I use this in the "sum" operator, the dimensions are deleted.
Exemple :
- sum(rho*mesh.V()) -> dimension is kg.
- sum(rho*mesh.V()*mesh.C().internalField() -> dimmensionless.
Is there a way to fix that ?
Aurelien Thinat is offline   Reply With Quote
Old   November 14, 2013, 13:50
David Gaden
marupio is on a distinguished road
Try .dimensionedInternalField()
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   November 15, 2013, 03:36
Aurelien Thinat
Wonderfull, it works ! Thank you very much.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Closed Volume: Mass increases, pressure and temperature decrease... vainilreb OpenFOAM Running, Solving & CFD 1 December 4, 2012 07:57
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
volume fraction, Mass fraction and Bulk Mass flow Dr.jones CFX 1 January 25, 2006 04:32
