Home > Forums > OpenFOAM Programming & Development
div and laplacian
Like Tree2Likes
  • 1 Post By Bernhard
  • 1 Post By ngj
Old   November 22, 2013, 10:18
Red face div and laplacian
Reza
gooya_kabir is on a distinguished road
Hi friends,
I want to generate some equations in open foam. My interest is to generate (d2v/dx2)+(d2v/dy2). But in openfoam there is "div" and "laplacian" commands which make equations in x, y and z directions and I want just in x and y directions. What can I do?
Thank you in advance for your help and comments.
Kind Regards
gooya_kabir is offline   Reply With Quote
Old   November 22, 2013, 10:32
Bernhard
Bernhard is on a distinguished road
Use a 2D mesh, i.e. flat and parallel front and back planes, with only one cell. Set the boundary conditions to empty.
gooya_kabir likes this.
Bernhard is offline   Reply With Quote
Old   November 22, 2013, 10:40
Reza
thanks for your response . But my geometry is 3D, and just I want to apply an equation which has gradient in x and y directions.?!
Old   November 23, 2013, 08:12
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hallo,
This basically means that you are solving a system in 3D, which is of the form:
1\cdot\frac{\partial^2 v}{\partial x^2} + 1\cdot\frac{\partial^2 v}{\partial y^2} + 0\cdot\frac{\partial^2 v}{\partial z^2} = 0
I believe that the Laplacian operator in OpenFoam does support a diffusivity as a tensor of rank two, which basically means that the above equation could be re-written as:
\nabla\boldsymbol{\cdot}\mathbf{\Gamma}\nabla v = 0
where
\mathbf{\Gamma} = \left[\begin{array}{ccc}1&0&0\\0&1&0\\0&0&0\end{array}\right]
and \nabla=(\partial/\partial x,\,\partial/\partial y,\,\partial/\partial y).
Good luck,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is online now   Reply With Quote
Old   November 25, 2013, 05:28
Reza
thank you. I think I could not transform my words. I want to apply the below equation, what's the mathematical description of this equation in open foam?
-∂p/∂x=μ((∂^2 v)/(∂y^2 )+(∂^2 v)/(∂z^2 ))
Originally Posted by ngj View Post
Hallo,
where
Good luck,
Niels
Thread Tools
Trackbacks are On
Question about scalar transport osimonsimon OpenFOAM Running, Solving & CFD 32 August 23, 2014 01:07
Passive scalar transport novyno OpenFOAM Running, Solving & CFD 9 September 6, 2012 06:52
Convection-diffusion in 1D : wrong solution for a large Delta x nuovodna OpenFOAM 15 October 20, 2010 13:36
Implementation of div, laplacian, etc and variables sven OpenFOAM 3 July 19, 2009 18:18
Dimensions of laplacian in PISO loop kumar2 OpenFOAM Running, Solving & CFD 2 July 3, 2006 14:34
