-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   corrupted double-linked list error when linking certain libraries (http://www.cfd-online.com/Forums/openfoam-programming-development/126794-corrupted-double-linked-list-error-when-linking-certain-libraries.html)
AlmostSurelyRob November 26, 2013 07:47
I encountered recently a very strange problem when linking one of my libraries to a variation of multiphaseEulerFoam. I have found already two work-arounds, but I do not understand fully what is happening and my feeling is that there's a bug somewhere either on my side or in multiphaseSystem library. If any one of you came across this please let me know.
I am linking a new library to STFMultiphaseEulerFoam which is a simple modification of multiphaseEulerFoam. The library has some run time selectibility through standard set of macros. On exit the application freezes and gives me this error
*** Error in `STFMultiphaseEulerFoam': corrupted double-linked list: 0x0000000001572a90 ***
This does not happen when I link the same library to a different solver (e.g. interFoam). Also it does not happen on intel compilers and it does not happen if I do not link shared libraries to my library but postpone linking until I compile the solver (workaround 1).
When I run this through valgrind I get this
==27221== Memcheck, a memory error detector
==27221== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==27221== Using Valgrind-3.9.0 and LibVEX; rerun with -h for copyright info
==27221== Command: STFMultiphaseEulerFoam
==27221==
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/c111269/projects/STFFoam.git/build/system/controlDict at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
==27221== Invalid read of size 4
==27221==    at 0x4E5C8E2: Foam::word::~word() (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libmultiphaseSystem.so)
==27221==    by 0x8CD322E: __cxa_finalize (in /usr/lib/libc-2.18.so)
==27221==    by 0x825C162: ??? (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libtwoPhaseProperties.so)
==27221==    by 0x400EEF9: _dl_fini (in /usr/lib/ld-2.18.so)
==27221==    by 0x8CD2EA8: __run_exit_handlers (in /usr/lib/libc-2.18.so)
==27221==    by 0x8CD2EF4: exit (in /usr/lib/libc-2.18.so)
==27221==    by 0x773BBBA: Foam::IOerror::exit(int) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so)
==27221==    by 0x77F9F74: Foam::regIOobject::readStream() (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so)
==27221==    by 0x77FA2F7: Foam::regIOobject::readStream(Foam::word const&) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so)
==27221==    by 0x77F4F13: Foam::IOdictionary::readFile(bool) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so)
==27221==    by 0x77F46FB: Foam::IOdictionary::IOdictionary(Foam::IOobject const&) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so)
==27221==    by 0x781C5A2: Foam::Time::Time(Foam::word const&, Foam::argList const&, Foam::word const&, Foam::word const&) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so)
==27221==  Address 0xbc15210 is 16 bytes inside a block of size 42 free'd
==27221==    at 0x4C28EAC: operator delete(void*) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==27221==    by 0x4E5C8F7: Foam::word::~word() (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libmultiphaseSystem.so)
==27221==    by 0x4E5A602: ??? (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libmultiphaseSystem.so)
==27221==
==27221== Invalid free() / delete / delete[] / realloc()
==27221==  Address 0xbc15200 is 0 bytes inside a block of size 42 free'd
==27221==
==27221==
==27221== HEAP SUMMARY:
==27221==    in use at exit: 2,540 bytes in 15 blocks
==27221==  total heap usage: 33,073 allocs, 33,059 frees, 3,293,055 bytes allocated
//some output removed
==27221==
==27221== 42 bytes in 1 blocks are definitely lost in loss record 9 of 15
==27221==    at 0x4C27CC2: operator new(unsigned long) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==27221==    by 0x85384F8: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.18)
==27221==    by 0x8539C30: char* std::string::_S_construct<char const*>(char const*, char const*, std::allocator<char> const&, std::forward_iterator_tag) (in /usr/lib/libstdc++.so.6.0.18)
==27221==    by 0x853A047: std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.18)
==27221==    by 0x825ADFF: _GLOBAL__sub_I_alphaContactAngleFvPatchScalarField.C (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libtwoPhaseProperties.so)
==27221==    by 0x400E8E9: call_init.part.0 (in /usr/lib/ld-2.18.so)
==27221==    by 0x400E9D2: _dl_init (in /usr/lib/ld-2.18.so)
==27221==    by 0x40012A9: ??? (in /usr/lib/ld-2.18.so)
// some output removed
==27221==
==27221== LEAK SUMMARY:
==27221==    definitely lost: 42 bytes in 1 blocks
==27221==    indirectly lost: 0 bytes in 0 blocks
==27221==      possibly lost: 442 bytes in 11 blocks
==27221==    still reachable: 2,056 bytes in 3 blocks
==27221==        suppressed: 0 bytes in 0 blocks
==27221== Reachable blocks (those to which a pointer was found) are not shown.
==27221== To see them, rerun with: --leak-check=full --show-leak-kinds=all
==27221==
==27221== For counts of detected and suppressed errors, rerun with: -v
==27221== ERROR SUMMARY: 16 errors from 14 contexts (suppressed: 2 from 2)
I removed "possibly lost" output. Please note the invalid free and that there's some data "definitely lost" and it is in _GLOBAL__sub_I_alphaContactAngleFvPatchScalarField .C. Following this I removed the corresponding C file and recompiled multiphaseSystem library, which caused the error to go away too (workaround 2).
note also that wmake when creating a shared object doesn't link. The only reason why I spotted this was due to cmake. I moved the compilation of my project to cmake and was doing linking when creating so too. As far as I understand this should not matter. If you have any suggestions please advise.
