corrupted double-linked list error when linking certain libraries |
November 26, 2013, 07:47 |
Robert Sawko
Rep Power: 22 |
I encountered recently a very strange problem when linking one of my libraries to a variation of multiphaseEulerFoam. I have found already two work-arounds, but I do not understand fully what is happening and my feeling is that there's a bug somewhere either on my side or in multiphaseSystem library. If any one of you came across this please let me know.
I am linking a new library to STFMultiphaseEulerFoam which is a simple modification of multiphaseEulerFoam. The library has some run time selectibility through standard set of macros. On exit the application freezes and gives me this error Code:
*** Error in `STFMultiphaseEulerFoam': corrupted double-linked list: 0x0000000001572a90 *** When I run this through valgrind I get this Code:
==27221== Memcheck, a memory error detector ==27221== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al. ==27221== Using Valgrind-3.9.0 and LibVEX; rerun with -h for copyright info ==27221== Command: STFMultiphaseEulerFoam ==27221== --> FOAM FATAL IO ERROR: cannot find file file: /home/c111269/projects/STFFoam.git/build/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting ==27221== Invalid read of size 4 ==27221== at 0x4E5C8E2: Foam::word::~word() (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libmultiphaseSystem.so) ==27221== by 0x8CD322E: __cxa_finalize (in /usr/lib/libc-2.18.so) ==27221== by 0x825C162: ??? (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libtwoPhaseProperties.so) ==27221== by 0x400EEF9: _dl_fini (in /usr/lib/ld-2.18.so) ==27221== by 0x8CD2EA8: __run_exit_handlers (in /usr/lib/libc-2.18.so) ==27221== by 0x8CD2EF4: exit (in /usr/lib/libc-2.18.so) ==27221== by 0x773BBBA: Foam::IOerror::exit(int) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77F9F74: Foam::regIOobject::readStream() (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77FA2F7: Foam::regIOobject::readStream(Foam::word const&) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77F4F13: Foam::IOdictionary::readFile(bool) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77F46FB: Foam::IOdictionary::IOdictionary(Foam::IOobject const&) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x781C5A2: Foam::Time::Time(Foam::word const&, Foam::argList const&, Foam::word const&, Foam::word const&) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== Address 0xbc15210 is 16 bytes inside a block of size 42 free'd ==27221== at 0x4C28EAC: operator delete(void*) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so) ==27221== by 0x4E5C8F7: Foam::word::~word() (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libmultiphaseSystem.so) ==27221== by 0x8CD322E: __cxa_finalize (in /usr/lib/libc-2.18.so) ==27221== by 0x4E5A602: ??? (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libmultiphaseSystem.so) ==27221== by 0x400EEF9: _dl_fini (in /usr/lib/ld-2.18.so) ==27221== by 0x8CD2EA8: __run_exit_handlers (in /usr/lib/libc-2.18.so) ==27221== by 0x8CD2EF4: exit (in /usr/lib/libc-2.18.so) ==27221== by 0x773BBBA: Foam::IOerror::exit(int) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77F9F74: Foam::regIOobject::readStream() (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77FA2F7: Foam::regIOobject::readStream(Foam::word const&) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77F4F13: Foam::IOdictionary::readFile(bool) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77F46FB: Foam::IOdictionary::IOdictionary(Foam::IOobject const&) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== ==27221== Invalid free() / delete / delete[] / realloc() ==27221== at 0x4C28EAC: operator delete(void*) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so) ==27221== by 0x4E5C8F7: Foam::word::~word() (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libmultiphaseSystem.so) ==27221== by 0x8CD322E: __cxa_finalize (in /usr/lib/libc-2.18.so) ==27221== by 0x825C162: ??? (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libtwoPhaseProperties.so) ==27221== by 0x400EEF9: _dl_fini (in /usr/lib/ld-2.18.so) ==27221== by 0x8CD2EA8: __run_exit_handlers (in /usr/lib/libc-2.18.so) ==27221== by 0x8CD2EF4: exit (in /usr/lib/libc-2.18.so) ==27221== by 0x773BBBA: Foam::IOerror::exit(int) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77F9F74: Foam::regIOobject::readStream() (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77FA2F7: Foam::regIOobject::readStream(Foam::word const&) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77F4F13: Foam::IOdictionary::readFile(bool) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77F46FB: Foam::IOdictionary::IOdictionary(Foam::IOobject const&) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== Address 0xbc15200 is 0 bytes inside a block of size 42 free'd ==27221== at 0x4C28EAC: operator delete(void*) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so) ==27221== by 0x4E5C8F7: Foam::word::~word() (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libmultiphaseSystem.so) ==27221== by 0x8CD322E: __cxa_finalize (in /usr/lib/libc-2.18.so) ==27221== by 0x4E5A602: ??? (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libmultiphaseSystem.so) ==27221== by 0x400EEF9: _dl_fini (in /usr/lib/ld-2.18.so) ==27221== by 0x8CD2EA8: __run_exit_handlers (in /usr/lib/libc-2.18.so) ==27221== by 0x8CD2EF4: exit (in /usr/lib/libc-2.18.so) ==27221== by 0x773BBBA: Foam::IOerror::exit(int) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77F9F74: Foam::regIOobject::readStream() (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77FA2F7: Foam::regIOobject::readStream(Foam::word const&) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77F4F13: Foam::IOdictionary::readFile(bool) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== by 0x77F46FB: Foam::IOdictionary::IOdictionary(Foam::IOobject const&) (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so) ==27221== ==27221== ==27221== HEAP SUMMARY: ==27221== in use at exit: 2,540 bytes in 15 blocks ==27221== total heap usage: 33,073 allocs, 33,059 frees, 3,293,055 bytes allocated //some output removed ==27221== ==27221== 42 bytes in 1 blocks are definitely lost in loss record 9 of 15 ==27221== at 0x4C27CC2: operator new(unsigned long) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so) ==27221== by 0x85384F8: std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.18) ==27221== by 0x8539C30: char* std::string::_S_construct<char const*>(char const*, char const*, std::allocator<char> const&, std::forward_iterator_tag) (in /usr/lib/libstdc++.so.6.0.18) ==27221== by 0x853A047: std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&) (in /usr/lib/libstdc++.so.6.0.18) ==27221== by 0x825ADFF: _GLOBAL__sub_I_alphaContactAngleFvPatchScalarField.C (in /home/c111269/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libtwoPhaseProperties.so) ==27221== by 0x400E8E9: call_init.part.0 (in /usr/lib/ld-2.18.so) ==27221== by 0x400E9D2: _dl_init (in /usr/lib/ld-2.18.so) ==27221== by 0x40012A9: ??? (in /usr/lib/ld-2.18.so) // some output removed ==27221== ==27221== LEAK SUMMARY: ==27221== definitely lost: 42 bytes in 1 blocks ==27221== indirectly lost: 0 bytes in 0 blocks ==27221== possibly lost: 442 bytes in 11 blocks ==27221== still reachable: 2,056 bytes in 3 blocks ==27221== suppressed: 0 bytes in 0 blocks ==27221== Reachable blocks (those to which a pointer was found) are not shown. ==27221== To see them, rerun with: --leak-check=full --show-leak-kinds=all ==27221== ==27221== For counts of detected and suppressed errors, rerun with: -v ==27221== ERROR SUMMARY: 16 errors from 14 contexts (suppressed: 2 from 2) note also that wmake when creating a shared object doesn't link. The only reason why I spotted this was due to cmake. I moved the compilation of my project to cmake and was doing linking when creating so too. As far as I understand this should not matter. If you have any suggestions please advise. |
Continuing User Defined Real Gas Model issues | aeroman | FLUENT | 6 | April 8, 2016 04:34 |
Parallel User Defined Real Gas Model | aeroman | FLUENT | 4 | July 1, 2015 07:09 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
