cell volume error
Like Tree1Likes
  • 1 Post By dkxls
Old   November 26, 2013, 06:43
Default cell volume error
Marshak is on a distinguished road
In my code I want to calculate the volume of each cell in the mesh to be used.
here below is the code:
forAll(Y, celli)
cell_volume[celli]=mesh.V()[celli];
z_y=cell_volume[celli]*Y[indexCO2][celli]/wCO2;
But I get following compilation error:
::mesh’ does not have class type
Can someone let me know what I am missing..do I need to add some header files etc. ??
Marshak is offline   Reply With Quote
Old   November 26, 2013, 07:44
Nima Samkhaniani
nimasam is on a distinguished road
may you want to try:
U.mesh.V()[celli]
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   November 26, 2013, 08:05
still the same error
Old   November 26, 2013, 08:19
Nima Samkhaniani
would you please post the whole error line
Old   November 29, 2013, 06:29
error: ‘U’ was not declared in this scope
I should mention that I am writing this code for thermal radiation modelling and only need to calculate volume of each cell in the mesh.
regards,
Old   November 29, 2013, 06:39
dkxls's Avatar
Armin
dkxls will become famous soon enough
It would be good if you could give some more information like:
Where do you implement this code? Solver, library, utility ...?
Is this part of a function or just in main?
And please use the 'CODE' tags when you post code or error messages (see http://www.cfd-online.com/Forums/ope...-get-help.html).
dkxls is offline   Reply With Quote
Old   November 29, 2013, 10:06
I have attached the files to compile (put in /thermophysical models/radiation models/submodels/absorptionEmissionModel). I get following errors:
submodels/absorptionEmissionModel/mygreyMeanAbsorptionEmission/mygreyMeanAbsorptionEmission.C: In member function ‘virtual Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::radiation::mygreyMeanAbsorptionEmission::aCo nt(Foam::label) const’:
submodels/absorptionEmissionModel/mygreyMeanAbsorptionEmission/mygreyMeanAbsorptionEmission.C:235:29: error: ‘((const Foam::radiation::mygreyMeanAbsorptionEmission*)thi s)->Foam::radiation::absorptionEmissionModel::mesh’ does not have class type
submodels/absorptionEmissionModel/mygreyMeanAbsorptionEmission/mygreyMeanAbsorptionEmission.C:237:2: error: ‘((const Foam::radiation::mygreyMeanAbsorptionEmission*)thi s)->Foam::radiation::absorptionEmissionModel::mesh’ does not have class type
submodels/absorptionEmissionModel/mygreyMeanAbsorptionEmission/mygreyMeanAbsorptionEmission.C:239:3: error: ‘pathLength’ was not declared in this scope
make: *** [Make/linux64GccDPOpt/mygreyMeanAbsorptionEmission.o] Error 1
Old   November 29, 2013, 10:28
dkxls's Avatar
Armin
Without looking much further into your code, I see there a quite wild mix of 'mesh', 'mesh()' and 'mesh_' throughout your code.
Here some hints on how to fix it:
The object 'mesh' is only defined in the constructor and can hence only be used there, i.e.
Foam::radiation::mygreyMeanAbsorptionEmission::mygreyMeanAbsorptionEmission
    const dictionary& dict,
    const fvMesh& mesh
In all other functions, you have to use:
this->mesh()
Check your base class (absorptionEmissionModel.H), to see what else you have access to.
Oh and btw, please read this: http://www.cfd-online.com/Forums/ope...-get-help.html
Especially, always post proper error messages and use 'CODE' tags!
nimasam likes this.
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
