December 3, 2013, 03:11 |
Inner product of tensor and vector
Johannes
Hello!
I try to implement an equation of scalar fluxes (an equation of type fvVectorMatrix) in OpenFOAM-1.6 where terms of an inner product of a tensor and a vector have to be calculated such as is a vector (volVectorField), so the first term is the inner product of a vector and a tensor is the Reynolds stress tensor and Z is a scalar (volScalarField), so the second term is the inner product of a symmetric tensor and a vector At the moment I wrote this in OpenFOAM as Code:
rho*Cs* uz & fvc::grad(U) + rho*turbulence->R() & fvc::grad(Z) Code:
ZEqns.H:36: error: no match for ‘operator==’ in ‘Foam::operator-(const Foam::tmp<Foam::fvMatrix<Type> >&, const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = Foam::Vector<double>](((const Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >&)((const Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >*)(& Foam::fvm::laplacian(const Foam::tmp<Foam::GeometricField<GType, Foam::fvPatchField, Foam::volMesh> >&, Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::Vector<double>, GType = Foam::SymmTensor<double>](((Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&)(& uz))))))) == Foam::operator*(const Foam::tmp<Foam::GeometricField<double, PatchField, GeoMesh> >&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam::compressible::turbulenceModel::R()))))’ /opt/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/perfectGasI.H:148: note: candidates are: Foam::perfectGas Foam::operator==(const Foam::perfectGas&, const Foam::perfectGas&) /opt/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/specieI.H:190: note: Foam::specie Foam::operator==(const Foam::specie&, const Foam::specie&) /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/triFaceI.H:304: note: bool Foam::operator==(const Foam::triFace&, const Foam::triFace&) /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/objectMapI.H:95: note: bool Foam::operator==(const Foam::objectMap&, const Foam::objectMap&) /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/objectHit.H:110: note: bool Foam::operator==(const Foam::objectHit&, const Foam::objectHit&) /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/cellShape.H:158: note: bool Foam::operator==(const Foam::cellShape&, const Foam::cellShape&) /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/cellModelI.H:124: note: bool Foam::operator==(const Foam::cellModel&, const Foam::cellModel&) /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/cell.H:134: note: bool Foam::operator==(const Foam::cell&, const Foam::cell&) /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/faceI.H:138: note: bool Foam::operator==(const Foam::face&, const Foam::face&) /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/edgeI.H:171: note: bool Foam::operator==(const Foam::edge&, const Foam::edge&) /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/instant.H:140: note: bool Foam::operator==(const Foam::instant&, const Foam::instant&) Thanks in advance for any comment! Greetings, Johannes |
December 3, 2013, 07:02 |
Bernhard
Rep Power: 21 |
The error message you give does not relate to the posted code, because there is no "==" in there.
December 3, 2013, 07:11 |
Johannes
Hello Bernhard!
Thank you for your reply. My fault, since I didn't post the whole equation, only two terms of it. Anyway, I guess I found a solution with which I'll come back a bit later to get an opinion from others. Greetings and let's "read" again in a while.... |
December 3, 2013, 13:03 |
possible solution
Johannes
As I sad before, I'll come back with a solution which I would like to share with you.
I finally implemented this equation = where is the vector (volVectorField) which has to be solved in OpenFOAM-1.6 as Code:
volVectorField R_Z = turbulence->R() & fvc::grad(Z); volVectorField uz_gU = uz & fvc::grad(U); fvVectorMatrix uzEqn ( fvm::ddt(rho, uz) + fvm::div(phi, uz) - fvm::laplacian(rho*C_s*turbulence->k()/turbulence->epsilon()*turbulence->R(), uz) == rho*(C_2 - 1)*uz_gU - rho*R_Z - rho*C_1*turbulence->epsilon()/turbulence->k()*uz ); Any comments? Is there a better way or more "stable form" to implement the equation? Thank you and kind regards, Johannes Last edited by jfw_cfd; December 4, 2013 at 11:59. |
July 7, 2014, 10:04 |
Xiangyu Gao
Rep Power: 12 |
Hi, Johannes
Have you got the solution to this problem? I am also facing the inner product of a tensor and a vector. Can you post the solution to this problem? Best regards, Xiangyu |
July 7, 2014, 10:33 |
proposed solution should work
Johannes
Hello Xiangyu!
Well, the solution of how to calculate the inner product of a tensor and a vector which I stated in my previous post should actually work (I guess you can see the code snippet). At least it worked for me (compiled and calculated). The instabilities I mentioned above, did not arise from this part of the code as far as I remember (all this happened quite some months ago...). Unfortunately, I don't have any further news about this topic. So I hope the above code works for you, which should be the case if just the inner product is the problem. Kind regards, Johannes |
July 7, 2014, 10:36 |
Xiangyu Gao
Rep Power: 12 |
Hi, Johannes!
Thank you very much for your reply! I just tried. Your solution works for my case perfectly! Thank you again for your help! Best regards, Xiangyu |
July 7, 2014, 10:41 |
Johannes
Perfect! That's good to hear, Xiangyu!
November 23, 2017, 08:39 |
PLD
Rep Power: 8 |
Hallo Johannes,
I am trying to implement a Rosenbrock-Wanner method in OpenFOAM for incompressible flows by modifying the icoFoam solver. At one part in my code I have to multiply a volTensorField with volVectorField (i.e. a dot product), for which I use the "&" symbol in OpenFOAM. The code compiles without errors but while running a case it gives the "segmentation fault (core dumped)" error. Here's the code snippet: Code:
phi = (fvc::interpolate(U)& mesh.Sf()); rhs.set(m,new volVectorField(runTime.deltaT()*(-fvc::div(phi,U)+ nu * fvc::laplacian(U)))); //the next line is where the error is being generated volVectorField slope = kihelp & (st-(g*runTime.deltaT()*symm(J))); fvVectorMatrix slopeE ( (fvm::Sp(1,slope)) == rhs[m] ); slopeE.solve(); So the equations I want to solve are in the form of Ax=b, where: matrix A = Identity - (scalar_const * delta_T * Jacobian) vector x = kihelp rhs b = function of Velocity. And here is how I declared the Identity matrix/tensor : Code:
GeometricField<symmTensor, fvPatchField, volMesh> st ( IOobject ( "st", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh, dimensioned<symmTensor>("st", dimless, symmTensor::one) zeroGradientFvPatchSymmTensorField::typeName ); Any help is appreciated. Thanks in advance |
January 21, 2018, 20:44 |
Vitor Geraldes
I am also facing the same problem. I have tried run this code:
#include "vector.H" #include "tensor.H" #include "IOstreams.H" using namespace Foam; int main() { tensor T(1, 0, 0, 0, 1, 0, 0, 0, 1); vector d(1, 1, 1); tensor TT = T*d; Info<< (TT) << endl; return 0; } but, the compiler displays an error when "tensor TT = T*d;" According to the programming manual, this should work. |
January 22, 2018, 04:14 |
#11 |
Johannes
Hi Vitor!
First of all, I have to admit that (unfortunately) I rather lost my close contact with OpenFOAM about two years ago. So I'm probably not the most adequate person to answer your (and Parthiv's) question. However, when looking at what you want to do and as far as my very limited mathematical background allows, I think a dot product of a tensor and a vector gives you a vector. So shouldn't TT be of type vector? Side note: T.d is not equal d.T Maybe this gives you an idea how to go on with your problem. To Parthiv: Sorry for this very late reply, but I'm not able to give you any solution at the moment. Maybe you fixed that already. If so, please post the solution. Good luck guys! |
