Home > Forums > OpenFOAM Programming & Development
difference between thermo.T() and T
Old   December 4, 2013, 08:39
Default difference between thermo.T() and T
Marshak is on a distinguished road
Can someone tell me what is the difference between defining
volScalarField myTemperature = thermo.T()
volScalarField mypressure = thermo.p()
and
const volScalarField& myTemperature = mesh_.lookupObject<volScalarField>("T");
const volScalarField& mypressure= mesh_.lookupObject<volScalarField>("p");
Marshak is offline   Reply With Quote
Old   December 4, 2013, 09:45
dkxls's Avatar
Armin
dkxls will become famous soon enough
Typically, in a solver that solves an energy equation (e.g. rhoPimpleFoam), the temperature is defined in the thermo class (see basicThermo.H).
You can access the field like this
const volScalarField& T = thermo.T();
(see e.g. createFields.H in the reactingFoam)
So, if you didn't implement some extra volScalarField named "T" (not quite sure if it is even possible to define two fields with the same same in the object registry), you should also be able to get access to the same field by looking it up from the object registry like this
const volScalarField& T = mesh.lookupObject<volScalarField>("T");
Note that you only get a const access to "T" from "thermo.T()".
dkxls is offline   Reply With Quote
Thread Tools
Trackbacks are On
high-order difference in OpenFOAM rxgrch OpenFOAM Programming & Development 4 July 8, 2016 12:50
Periodic Boundary Condition for upwind difference yohey44 Main CFD Forum 0 October 27, 2010 13:10
paraview - plotting difference to reference data joewe ParaView 0 August 30, 2010 18:01
Difference between scaled residuals and... Dieter FLUENT 0 April 28, 2006 17:52
Fininte difference and Finite element Technique Mahendra Singh Mehra FLUENT 3 December 23, 2005 00:49
