Creating My First Solver
Old   February 21, 2015, 19:53
Default Creating My First Solver
Alex
H0T_S0UP is on a distinguished road
I am creating my own solver. Basically, it is a modification of laplacianFoam - I am solving a heat transfer problem with a source term included. It is creatively named "OwnSolverFoam" haha
I have modified createFields.H, OwnSolverFoam.C, Make/files and created a new tutorial directory for my case. running wmake yielded no errors. No errors within the tutorial were encountered too. However, when I go to run the case I get a message stating the command is not found:
skankatron@skankatron-Q551LN:/opt/openfoam231/tutorials/basic/OwnSolverFoam/flange$ OwnSolverFoamOwnSolverFoam: command not found
H0T_S0UP is offline   Reply With Quote
Old   February 23, 2015, 08:02
blacksquirrel is on a distinguished road
Hi Alex,
since in your error message the name of the solver is written two times, are you sure you typed "OwnSolverFoam" only once?
Did you modify Make/files with
EXE = $(FOAM_USER_APPBIN)/OwnSolverFoam
Next step would be
echo $FOAM_USER_APPBIN
Then go into the shown folder and look whether you can find your OwnSolverFoam
If yes, then the command should be found. Please pay attention to lower and uppercase in the name.
blacksquirrel is offline   Reply With Quote
Error while using my solver samiam1000 OpenFOAM Programming & Development 6 June 13, 2012 08:53
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Creating a new solver from chtMultiRegionFoam David_010 OpenFOAM Programming & Development 0 April 20, 2010 11:36
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
