adapting sprayDyMFoam-solver to OpenFOAM-2.2.x
2 Attachment(s)
Hi everyone,
as the title tells you I'm trying to adapt an existing sprayDyMFoam-solver from OpenFOAM 2.1.x to 2.2.x . As you surely know there have been some changes concerning the amount and names of Header-files in OpenFOAM, this is the reason why the 2.1.x-Version of sprayDyMFoam won't work on 2.2.x . The changes I've done so far: - added missing header-files - header-files which don't exist in 2.2.x were commented out and partly replaced by 2.2.x header-files - renamed hsEqn.H to EEqn.H for consistency reasons - changed the content of some header-files ( pEqn.H, EEqn.H, YEqn.H etc.), because of the version differences between 2.1.x and 2.2.x - replaced the function sources() with fvOptions() When I tried to compile the solver some issues ocurred. Example: sprayDyMFoam.C: (.text + 0x7a19): undefined reference to `Foam::fv::IOoptionList::IOoptionList(Foam::fvMesh const&)' See also attached log.wmake-file. Does anyone had the same problem or know how to fix it? Attached you'll find the original and the adapted solver as well as the compilation log-file. Thank you in advance. |
Hi everyone,
I found the initial issue. Some libraries haven't been linked by me and some small adjustments had to be made. I also didn't validate it yet. If there are some news i'll post them here. |
