Problem with compiling new solver
Old   December 23, 2013, 21:43
Thumbs down Problem with compiling new solver
Karol Kamiński
palazi88 is on a distinguished road
Hello!
Some time ago I created new solver, which worked on computer (so code is for sure OK), and now I tried to compile it on my personal computer. But after going to apropriate folder and writing command:
"bash ./Allwmake"
I got loads of warnings and error. Below in file you can find all messages from shell.
Last line is in polish language:
"make: *** Brak reguł do wykonania obiektu `chtMRSimpleFSource'. Stop."
and it means:
"make: *** No rules to make a target `chtMRSimpleFSource'. Stop."
I also made a test: I copied other OpenFoam solver, and I changed only it's name. After that I tried to compile this "new" solver, but I got very similar warnings and errors.
I have no idea what's going on. Is there anyone who can help me with this problem? It's really annoying :/
Thanks for all help!
[edited]
I forgot to add: I am using 2.1.x OF version
Anyway, now I see, that almost all warning and errors come from libfiniteVolume.so, maybe it's a problem with path to fvCFD.H file? If yes, how can I change it?
palazi88 is offline   Reply With Quote
Old   December 24, 2013, 04:14
Bernhard
Bernhard is on a distinguished road
Did you run a proper wclean first?
Then, check Make/options and Make/files.
Bernhard is offline   Reply With Quote
Old   December 24, 2013, 19:52
Karol Kamiński
Thanks for fast reply!
Making "wclean" was not a problem but... ... I made one other idiotic error... I just thought that I need to write command "wmake <name of new solver>" when I want to compile a new solver... I forgot that I need only "wmake" command, when I am in apropriate folder. Because name of my folder and name of my new solver were different, so it didn't work. Now everything works fine. Sorry for wasting your time
solver compilation error
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Solver problem in Oscillating Plate tutorial vovogoal CFX 1 November 22, 2011 09:54
Problem in Compiling the solver m.maneshi OpenFOAM Running, Solving & CFD 4 November 3, 2010 02:07
problem with developing new LES solver Edison_Ge OpenFOAM 2 June 18, 2009 01:26
