Problem with compiling new solver
1 Attachment(s)
Hello!
Some time ago I created new solver, which worked on computer (so code is for sure OK), and now I tried to compile it on my personal computer. But after going to apropriate folder and writing command: "bash ./Allwmake" I got loads of warnings and error. Below in file you can find all messages from shell. Last line is in polish language: "make: *** Brak reguł do wykonania obiektu `chtMRSimpleFSource'. Stop." and it means: "make: *** No rules to make a target `chtMRSimpleFSource'. Stop." I also made a test: I copied other OpenFoam solver, and I changed only it's name. After that I tried to compile this "new" solver, but I got very similar warnings and errors. I have no idea what's going on. Is there anyone who can help me with this problem? It's really annoying :/ Thanks for all help! [edited] I forgot to add: I am using 2.1.x OF version Anyway, now I see, that almost all warning and errors come from libfiniteVolume.so, maybe it's a problem with path to fvCFD.H file? If yes, how can I change it? |
Did you run a proper wclean first?
Then, check Make/options and Make/files. |
Thanks for fast reply!
Making "wclean" was not a problem but...:o ... I made one other idiotic error... I just thought that I need to write command "wmake <name of new solver>" when I want to compile a new solver... I forgot that I need only "wmake" command, when I am in apropriate folder. Because name of my folder and name of my new solver were different, so it didn't work. Now everything works fine. Sorry for wasting your time |
