Home > Forums > OpenFOAM Programming & Development
problem with modifyPatches
Old   January 3, 2014, 06:25
Post problem with modifyPatches
sam.ho is on a distinguished road
Hi Foamers,
I am simulating a valve and the mesh has been extracted from fluent.
In this i supposed to change patch type from patch to wall .
I followed the procedure
1. copies zip file from wikiOpenFOAM to case directory
2. unzipped it
3. navigated to modifyPatches directory
4. run a command wclean\
5. then again ran a command wmake.
6. Navigated back to case directory and ran a command modifyPatches -wall SUPPORT
but it says modifyPatches: command not found.
Anybody please help me ?
sam.ho is offline   Reply With Quote
Old   January 5, 2014, 01:47
Nima Sam
nimasam is on a distinguished road
Send a message via Yahoo to nimasam
your description is too vague to import mesh file from fluent, export it as .msh
then import it by one of following commands depend on it is 2D or 3D
fluentMeshToFoam
fluent3DMeshToFoam
after mesh is imported in OpenFOAM, you can change th BC from boundary file in constant/polyMesh
Training Course on OpenFOAM at (http://www.isme.ir/)
My Weblog (http://openfoam.blogfa.com/)
nimasam is offline   Reply With Quote
Old   January 6, 2014, 05:12
Hi
I imported mesh then checked for its quality and everything was fine then i followed the procedure explained earlier to change boundary patch type from patch to wall.
1. copied modifyPatches zip file from wikiOpenFOAM to case directory
2. unzipped it
Thread Tools
Trackbacks are On
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
