new radial equilibrium pressure BC for turbomachinery |
April 3, 2013, 13:43 |
Rep Power: 17 |
Hi everyone,
this is my first attempt at a new BC for OF. what i am trying to implement is the 'standard' radial equilibrium pressure BC which is used in many turbomachinery simulations. i.e., where the pressure at the outlet is governed according to: I have a little experience with groovyBC, and have used it to set up an inlet velocity profile using lookup_tables, but now need to decide how to build the outlet BC. So basically, my questions are: 1) which would be easier - building the BC using groovyBC, or coding up a 'proper' new BC in c++ and linking to that 2) any hints as to how to go about this in either case - ie if coding one up, which BC existing BC to start with etc how difficult do you expect this would be to implement in general (my c++ is coming along, but i am no expert as yet) and i am under a little bit of pressure to get it done many thanks in advance cheers jon |
April 4, 2013, 05:52 |
Rep Power: 17 |
hi guys !
any ideas? comments?? many thanks! Jonathan |
April 4, 2013, 14:09 |
I have an old piece of code which was written in FOAM-1.5-dev.
The idea is quite simple: 1) construct a regular grid of points in cylindrical coordinates that covers the entire patch. 2) map velocity field on the regular grid 3) construct pressure field on the regular grid based on radial derivatives and a reference pressure at the hub 4) map back regular grid pressure on the patch Hope this will be a good starting point for you, please let me know if you find some difficulties and do not hesitate to share the code once imported in current versions of OpenFOAM.
Cosimo Bianchini Ergon Research s.r.l. Via Panciatichi, 92 50127 Florence - ITALY Tel: +39 055 0763716 Mob: +39 320 9460153 e-mail: cosimo.bianchini@ergonresearch.it URL: www.ergonresearch.it |
April 7, 2013, 18:08 |
Rep Power: 17 |
hi Cosimo,
thanks very much for your help and the piece of code. i will try to give it a go and see how i go. i have been playing around with some code which lets the pressures over the patch fluctuate but constrains the integral of the pressure over the patch to a mean value, so the radial pressure gradients should come out in the solution, but will give your code a shot as well as it may give better results ... i'll let you know how it goes! many thanks kind regards jonathan |
August 29, 2013, 12:40 |
Did you get any good solution for the radial equilibrium BC?
August 30, 2013, 07:41 |
Rep Power: 17 |
hi Cosimo,
thanks for the post! the short answer was no - your c++ was a little over my head, and so i have been using a fixedMeanValue BC, and letting the flow solution figure hammer out the radial equilibrium, rather than enforcing it. my results are comparable to those i get in Fluent, with the radialEquilibrium BC. however, i have done quite a lot of c++ work in the last months, and depending on whether my supervisor wants me to follow that route, i might have to go back to it, in which case, your code will be my starting template. best regards jonathan |
January 2, 2014, 03:31 |
Zhiyuan Li
Rep Power: 12 |
Hi Cosimo,
I am trying to compile the code you have shared in Openfoam 2.2.1.But the Openfoam don't have a file named regularGridPolyPatch.H. (regularGridFvPatch / #include "regularGridPolyPatch.H") I even don't find regularGridPolyPatch.H in Openfoam 1.5. Have you compile the BC in Openfoam 1.5 or other new versions? Do you meet this problem? best regards Zhiyuan |
January 6, 2014, 06:05 |
The code for regularGridPolyPatch is part of the development I made for this radial equilibrium BC, you can find it in RadialEquilibrium.zip .
Hope you suceed in compiling the code and provide some feedback. Regards, Cosimo
January 6, 2014, 22:01 |
#9 |
Zhiyuan Li
Rep Power: 12 |
Hi Cosimo,
Thank you for your reply.Unfortunately, I can't find the code for regularGridPolyPatch in your development. There is only a head file named as regularGridFvPatch.H. Maybe you forget to compress the file into RadialEquilibrium.zip. best regards Zhiyuan |
Display Modes | |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 15:32 |
Setting Pressure outlet boundary for simulation of Radial impeller | Mukund Pondkule | Main CFD Forum | 1 | April 5, 2011 10:24 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 18:19 |
use of radial equilibrium press. in 2 phase flow | James Willie | FLUENT | 0 | May 2, 2005 12:26 |
