BCs and correctBoundaryConditions() for an electric field and current solver |
January 21, 2014, 06:56 |
#1 | |
Rep Power: 18 |
I'm working on a solver for calculating electric field and current in an inhomogenous conductivity field. I'm currently evaluating the validity of the solution and I'm wondering which boundary conditions make most sense, and which fields need to use field.correctBoundaryConditions(). To my understanding correctBoundaryConditions() adjusts the values of the boundary so they match their gradient conditions after the values of the cells were (explicitly) modified. Here's a simplified excerpt of the solver code: Code:
forAll(sigma, iter) { sigma[iter] = someValues; } sigma.correctBoundaryConditions(); int i = 0; while(i < 10) { i++; //quasistatic electric potential fvScalarMatrix phiEqn ( fvm::laplacian(sigma, phiE) ); Foam::solverPerformance phiSolve = phiEqn.solve(); //electric field EField = -fvc::grad(phiE); //EField.correctBoundaryConditions(); //current density j = sigma * EField; //j.correctBoundaryConditions(); Info << "phiE: " << min(phiE) << "/" << max(phiE) << endl; if(phiSolve.nIterations() == 0 && phiSolve.converged()) { Info << "phi equation converged in " << i << " iterations" << endl; break; } } Electric field and current both use zeroGradient BC, although I would prefer to use a BC that has zeroGradient in normal direction and fixedValue 0 in tangential direction. Is there such a BC? For testing, I've used zeroGradient for the conductivity and I'm having some numerical problems. Below you can see the output of the calculated current using different methods, with j being the current density: Quote:
I also expect that the difference between the electrodes should be (close to) zero, meaning that the current is conserved. However, there is a significant error. I am using a simple wedge mesh generated with blockMesh. The electrodes have different angles towards each other, one at the top, one at the bottom, and one at the side of the cylindrical mesh, separated by isolating material with zero conductivity BC. Right now the cells are completely orthogonal. I believe this could be caused by the somewhat unfitting zeroGradient BC for electric field and current, but I don't know if there is such a condition as described above. I would be very grateful if someone could give me some hints. It is important to me to get current conservation (atleast to a certain accuracy). By the way, can anyone explain to me the meaning of phiSolve.nIterations() and phiSolve.converged() ? I suspect this is related to the way the solution matrix is approximated, but if it is, why does the loop in the solver above has to run multiple times until the solution converges? I would expect the solver to iterate until conversion is reached. Is there some artificial limit that stops it before convergence? Last edited by chriss85; January 22, 2014 at 03:55. |
May 2, 2022, 21:25 |
Mostafa
Rep Power: 4 |
hello chriss85,
I know it has been a long time, but I'm also solving electric field after computing electric potential in multiregion solver. i could not get continous electric field across interface. do you have any suggestion how to solve the problem thanks in advance |
May 3, 2022, 10:32 |
Rep Power: 18 |
I don't remember from my head, I think it was about prescribing either current continuity or potential. It might be easier if you have a current source and know what current needs to be pass through the interface in total. In that case you could solve one region first to calculate the potential and then apply that potential to the other region. This will only work if you can assume a vastly different conductivity so that you have an equipotential surface at the interface. Otherwise I think you will need some iterative solution.
Another possibility would be using a third mesh that encompasses both meshes, solve the equation on that mesh and then project the solution on the other two regions. |
May 3, 2022, 12:08 |
Mostafa
Rep Power: 4 |
Thank chriss85 for your reply ,
let me explain my problem well. I successfully solved the electric potential (phi) over fluid and solid mesh and I got continuous electric potential through coupling the two domains using iterative class ( compressible Turbulent Baffle) to set equal fluxes across interface which is used in heat transfer problems. My question is regarding the Electric field : E = -fvc::grad(phi) although I had continuous electric potential (phi) across interface, i failed to get a continuous electric field across the interface after taking the gradient of phi what i did is that in the fluid domain i solved the electric potential and then took the derivative solve ( fvm::laplacian(epsilon,phiS) ); E = -1*fvc::grad(phiS); and also i did the same in solid regions solve ( fvm::laplacian(epsilon,phiS) ); E = -1*fvc::grad(phiS); in electric field file in the zero file , i set all the boundaries to calculated i'm asking about how the fvc::grad() can compute continous electric field (E) while computing every one on seperate mesh Thanks in advance |
May 3, 2022, 12:29 |
#5 | |
Mostafa
Rep Power: 4 |
i calculated the electric potential over fluid and solid and coupled them using compressibleBaffle class then i mapped the phi on the solid mesh and in the fluid mesh over on mesh contianing both meshes to have one elecctric potential field using MapField , after thaty i took the gradient successfully and got the right Electric field the problem is mapField took long time about 3 hrs to map field (phi) from solid domain to its projection on the full mesh and other 3 hrs to map field (phi) from fluid domain to it's projection on the full mesh , so i cannot do this all time |
