Home > Forums > OpenFOAM Programming & Development
Query on blockMesh creation
Old   January 24, 2014, 12:05
Default Query on blockMesh creation
Jeremy Dudley
bendel_boy is on a distinguished road
I get a message 'Fatal error: inconsistent number of faces between block pair 2 and 3'
BUT block 2 is supposed to be 20 m (long) x 1.35 m, block 3 20 m x 0.15 m, and the blocks are supposed to be split into 200 x 27 cells and 200 x 3 cells ( so each cell 0.1 x 0.05 m).
Any suggestions for what I am doing wrong?
The dictionary contents follow.
convertToMeters 1;
vertices
( 0 0 0) // 0
( 0.3 0 0) // 1
(30 0 0) // 2
(30 1.5 0) // 3
(30 2.85 0) // 4
(30 3 0) // 5
(10 3 0) // 6
(10 1.5 0) // 7
( 9.5 1.5 0) // 8
( 9.5 2 0) // 9
( 9.5 2.3 0) // 10
( 9.5 3 0) // 11
( 0 3 0) // 12
( 0 2.3 0) // 13
( 0 2 0) // 14
( 0 1.5 0) // 15
(0.3 1.5 0) // 16
(10 2.85 0) // 17
( 0 0 3) // 18
( 0.3 0 3) // 19
(30 0 3) // 20
(30 1.5 3) // 21
(30 2.85 3) // 22
(30 3 3) // 23
(10 3 3) // 24
(10 1.5 3) // 25
( 9.5 1.5 3) // 26
( 9.5 2 3) // 27
( 9.5 2.3 3) // 28
( 9.5 3 3) // 29
( 0 3 3) // 30
( 0 2.3 3) // 31
( 0 2 3) // 32
( 0 1.5 3) // 33
(0.3 1.5 3) // 34
(10 2.85 3) // 35
// Allow for a 10 cm x 5 cm block
blocks
hex ( 0 1 16 15 18 19 34 33) ( 3 30 1) simpleGrading (1 1 1) // B0; 0.3 x 1.5
hex ( 1 2 3 16 19 20 21 34) (297 30 1) simpleGrading (1 1 1) // B1; 29.7 x 1.5
hex ( 3 4 17 7 21 22 35 25) (200 27 1) simpleGrading (1 1 1) // B2; 20 x 1.35
hex ( 4 5 6 17 22 23 24 35) (200 3 1) simpleGrading (1 1 1) // B3; 20 x 0.15
hex (11 12 13 10 29 30 31 28) ( 95 14 1) simpleGrading (1 1 1) // B4; 9.5 x 0.7
hex (13 14 9 10 31 32 27 28) ( 95 6 1) simpleGrading (1 1 1) // B5; 9.5 x 0.3
hex (14 15 8 9 32 33 26 27) ( 3 6 1) simpleGrading (1 1 1) // B6; 0.3 x 0.5
edges
boundary
inlet // Patch 0
type patch;
faces
(14 13 31 32)
outlet // Patch 1
type patch;
faces
(5 4 22 23)
bottom // Patch 2
type wall;
faces
(1 0 18 19)
(2 1 19 20)
endWall // Patch 3
type wall;
faces
(3 2 20 21)
(4 3 21 22)
nearWall // Patch 4
type wall;
faces
(13 12 30 31)
(15 14 32 33)
( 0 15 33 18)
surface // Patch 5
type wall;
faces
( 6 5 23 24)
(12 11 29 30)
otherSurface // Patch 6
type empty;
faces
( 0 1 16 15)
( 1 2 3 16)
( 3 4 17 7)
( 4 5 6 17)
(11 12 13 10)
(13 14 9 10)
(14 15 8 9)
(18 19 34 33)
(19 20 21 34)
(21 22 35 25)
(22 23 24 35)
(29 30 31 28)
(31 32 27 28)
(32 33 26 27)
mergePatchPairs
bendel_boy is offline   Reply With Quote
Old   January 24, 2014, 12:51
startingWithCFD is on a distinguished road
Take a look at: http://www.openfoam.org/docs/user/bl...#x25-1420005.3
The xyz direction depends on the sequence of vertices in your blocks.
For example, in block 2, what you think as "x" is in reality "y" and what you think as "y" is in reality "x".
Just comment all blocks except block 2, visualize and use the "show orientation axes" button to see what I mean.
The solution is to properly rearrange the vertices in your blocks.
startingWithCFD is offline   Reply With Quote
Old   January 24, 2014, 18:24
Jeremy Dudley
Thank you. That resolved the problem.
Thread Tools
Trackbacks are On
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
blockMesh | MergePatchPairs | snappyHexMesh |Different number of cells in divisions pythag0ra5 OpenFOAM Native Meshers: blockMesh 0 October 25, 2013 11:49
set of xyz data in blockMesh psk OpenFOAM Native Meshers: blockMesh 12 August 27, 2013 08:37
tutorial 2.2 Stress(...) trouble with blockMesh colinB OpenFOAM Native Meshers: blockMesh 8 January 22, 2012 11:32
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 12:59
