January 24, 2014, 11:05 |
Query on blockMesh creation
Jeremy Dudley
I get a message 'Fatal error: inconsistent number of faces between block pair 2 and 3'
BUT block 2 is supposed to be 20 m (long) x 1.35 m, block 3 20 m x 0.15 m, and the blocks are supposed to be split into 200 x 27 cells and 200 x 3 cells ( so each cell 0.1 x 0.05 m). Any suggestions for what I am doing wrong? The dictionary contents follow. convertToMeters 1; vertices ( ( 0 0 0) // 0 ( 0.3 0 0) // 1 (30 0 0) // 2 (30 1.5 0) // 3 (30 2.85 0) // 4 (30 3 0) // 5 (10 3 0) // 6 (10 1.5 0) // 7 ( 9.5 1.5 0) // 8 ( 9.5 2 0) // 9 ( 9.5 2.3 0) // 10 ( 9.5 3 0) // 11 ( 0 3 0) // 12 ( 0 2.3 0) // 13 ( 0 2 0) // 14 ( 0 1.5 0) // 15 (0.3 1.5 0) // 16 (10 2.85 0) // 17 ( 0 0 3) // 18 ( 0.3 0 3) // 19 (30 0 3) // 20 (30 1.5 3) // 21 (30 2.85 3) // 22 (30 3 3) // 23 (10 3 3) // 24 (10 1.5 3) // 25 ( 9.5 1.5 3) // 26 ( 9.5 2 3) // 27 ( 9.5 2.3 3) // 28 ( 9.5 3 3) // 29 ( 0 3 3) // 30 ( 0 2.3 3) // 31 ( 0 2 3) // 32 ( 0 1.5 3) // 33 (0.3 1.5 3) // 34 (10 2.85 3) // 35 ); // Allow for a 10 cm x 5 cm block blocks ( hex ( 0 1 16 15 18 19 34 33) ( 3 30 1) simpleGrading (1 1 1) // B0; 0.3 x 1.5 hex ( 1 2 3 16 19 20 21 34) (297 30 1) simpleGrading (1 1 1) // B1; 29.7 x 1.5 hex ( 3 4 17 7 21 22 35 25) (200 27 1) simpleGrading (1 1 1) // B2; 20 x 1.35 hex ( 4 5 6 17 22 23 24 35) (200 3 1) simpleGrading (1 1 1) // B3; 20 x 0.15 hex (11 12 13 10 29 30 31 28) ( 95 14 1) simpleGrading (1 1 1) // B4; 9.5 x 0.7 hex (13 14 9 10 31 32 27 28) ( 95 6 1) simpleGrading (1 1 1) // B5; 9.5 x 0.3 hex (14 15 8 9 32 33 26 27) ( 3 6 1) simpleGrading (1 1 1) // B6; 0.3 x 0.5 ); edges ( ); boundary ( inlet // Patch 0 { type patch; faces ( (14 13 31 32) ); } outlet // Patch 1 { type patch; faces ( (5 4 22 23) ); } bottom // Patch 2 { type wall; faces ( (1 0 18 19) (2 1 19 20) ); } endWall // Patch 3 { type wall; faces ( (3 2 20 21) (4 3 21 22) ); } nearWall // Patch 4 { type wall; faces ( (13 12 30 31) (15 14 32 33) ( 0 15 33 18) ); } surface // Patch 5 { type wall; faces ( ( 6 5 23 24) (12 11 29 30) ); } otherSurface // Patch 6 { type empty; faces ( ( 0 1 16 15) ( 1 2 3 16) ( 3 4 17 7) ( 4 5 6 17) (11 12 13 10) (13 14 9 10) (14 15 8 9) (18 19 34 33) (19 20 21 34) (21 22 35 25) (22 23 24 35) (29 30 31 28) (31 32 27 28) (32 33 26 27) ); } ); mergePatchPairs ( ); |
January 24, 2014, 11:51 |
Take a look at: http://www.openfoam.org/docs/user/bl...#x25-1420005.3
The xyz direction depends on the sequence of vertices in your blocks. For example, in block 2, what you think as "x" is in reality "y" and what you think as "y" is in reality "x". Just comment all blocks except block 2, visualize and use the "show orientation axes" button to see what I mean. The solution is to properly rearrange the vertices in your blocks. |
January 24, 2014, 17:24 |
Jeremy Dudley
Thank you. That resolved the problem.
[blockMesh] blockMesh | MergePatchPairs | snappyHexMesh |Different number of cells in divisions | pythag0ra5 | OpenFOAM Meshing & Mesh Conversion | 1 | September 19, 2020 14:38 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
[blockMesh] set of xyz data in blockMesh | psk | OpenFOAM Meshing & Mesh Conversion | 12 | August 27, 2013 08:37 |
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh | colinB | OpenFOAM Meshing & Mesh Conversion | 8 | January 22, 2012 10:32 |
Blockmesh cavity error message | tonitoney | OpenFOAM Installation | 2 | March 17, 2008 11:59 |
