Custom boundary condition: unexpected behavior with chtMultiRegionFoam
Dear OpenFOAM users,
I recently wrote a simple custom boundary condition which computes the fluid velocity at the wall using a formula of the type: v = f(rho) * normal While my code yields the expected results using the rhoPimpleFoam solver, everything is messed up when using it with chtMultiRegionFoam, even though I use the exact same parameters for the BC. The near-wall velocity has an inverted orientation, and the upstream flow has a stagnation point, even if the wall velocity is oriented downstream. This is obviously a physical and numerical nonsense ... Is there something in particular that should be taken care of when using chtMultiRegionFoam with custom BCs? Parameters with rhoPimpleFoam: Code:
squareWall With chtMultiRegionFoam: Code:
fluid_to_solid |
Update
A little progress update: I went through the code and did some additional debugging. The coordinates of velocity on the patch seem to be computed correctly: I checked the values in the output files.
The results with a surfaceNormalFixedValue BC are okay: https://www.dropbox.com/s/zui2qaz9tz...FixedValue.png I'm guessing something wrong happens when running the updateCoeffs() method, maybe I shouldn't use the fixedValueFvPatchVectorField::operator==() member function? |
Update
I ran an additional test using swak4foam:
fluid_to_solid https://www.dropbox.com/s/0yjr5vca1y..._swak4foam.png |
Update
1 Attachment(s)
I computed the mass flux using the patchIntegrate utility.
Solver: chtMultiRegionFoam (using BCs for isothermal flow) Inlet mass flux: 0.000811 kg/s 1. BC: surfaceNormalFixedValue, -0.001 fluid_to_solid mass flux: 0.000463 kg/s Outlet mass flux: 0.00127 kg/s 2. BC: groovyBC, "- 0.001 * normal()" fluid_to_solid mass flux: <something>e-20 = 0 kg/s Outlet mass flux: 0.000811 kg/s Mass conversation seems to be okay. Something might be going wrong with the phi field, because the value of U at the boundary seems to be fine: Code:
value nonuniform List<vector> |
