Writing face centre values
Old   February 8, 2014, 07:09
Default Writing face centre values
Ashwani
AshwaniAssam is on a distinguished road
Hi all,
Is runTime.write() is only for writing volume fields? If yes what is the equivalent for writing face values.
For
surfaceScalarField Mach_sf = M_Lplus +M_Rminus;
I want to write at runtime value of Mach_sf.
Ashwani
AshwaniAssam is offline   Reply With Quote
Old   February 28, 2014, 11:11
Mohammad Shakil Ahmmed
ahmmedshakil is on a distinguished road
You can have a look at the writeCellCentres utility, and Mach_sf.write() should work .
ahmmedshakil is offline   Reply With Quote
Old   March 2, 2014, 04:01
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good morning,
No, runTime outputting also works for surfaceField<Type>, but you should make sure that you do not define your field inside a scope, such that it is deleted, once runTime.write() is executed.
If these things is not a problem, then it might be the write properties of the field, which can be changed with something along the following line:
fieldName.regIOobject::writeOpt() = IOobject::AUTO_WRITE;
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
Assigning face values into nodes syavash FLUENT 2 September 19, 2012 20:46
face and cell centered values danihuso OpenFOAM 0 July 17, 2009 11:01
