Home > Forums > OpenFOAM Programming & Development
Error adding the temperature icoFoam
Old   February 14, 2014, 23:11
Default Error adding the temperature icoFoam
JuNNioR
jrsilvio_ver is on a distinguished road
Dear, good night.
I used the openfoamwiki's tutorial to edit the solve icoFoam and add the energy equation, however when trying to visualize the temperature field, it simply disappears.
Below is example solver and edited example cavity.
I appreciate everyone's attention.
createFields.H
Info<< "Reading transportProperties\n" << endl;
    IOdictionary transportProperties
        IOobject
        "transportProperties",
        runTime.constant(),
        mesh,
        IOobject::MUST_READ,
        IOobject::NO_WRITE
    dimensionedScalar nu
        transportProperties.lookup("nu")
dimensionedScalar DT
     transportProperties.lookup("DT")
    Info<< "Reading field p\n" << endl;
    volScalarField p
        IOobject
            "p",
            runTime.timeName(),
            mesh,
            IOobject::AUTO_WRITE
        mesh
    Info<< "Reading field U\n" << endl;
    volVectorField U
        IOobject
            "U",
            runTime.timeName(),
            mesh,
        mesh
Info<< "Reading field T\n" <<endl;
volScalarField T
    IOobject
         "T",
         runTime.timeName(),
         mesh,
     mesh
#   include "createPhi.H"
    label pRefCell = 0;
    scalar pRefValue = 0.0;
    setRefCell(p, mesh.solutionDict().subDict("PISO"), pRefCell, pRefValue);
icoFoamTemp.C
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | Copyright (C) 2011-2012 OpenFOAM Foundation
     \\/     M anipulation  |
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
Application
    icoFoamTemp
Description
    Transient solver for incompressible, laminar flow of Newtonian fluids.
#include "fvCFD.H"
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "createFields.H"
    #include "initContinuityErrs.H"
    Info<< "\nStarting time loop\n" << endl;
    while (runTime.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        #include "readPISOControls.H"
        #include "CourantNo.H"
        fvVectorMatrix UEqn
            fvm::ddt(U)
          + fvm::div(phi, U)
          - fvm::laplacian(nu, U)
        solve(UEqn == -fvc::grad(p));
        // --- PISO loop
        for (int corr=0; corr<nCorr; corr++)
            volScalarField rAU(1.0/UEqn.A());
            volVectorField HbyA("HbyA", U);
            HbyA = rAU*UEqn.H();
            surfaceScalarField phiHbyA
                "phiHbyA",
                (fvc::interpolate(HbyA) & mesh.Sf())
              + fvc::ddtPhiCorr(rAU, U, phi)
            adjustPhi(phiHbyA, U, p);
            for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
                fvScalarMatrix pEqn
                    fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
                pEqn.setReference(pRefCell, pRefValue);
                pEqn.solve();
                if (nonOrth == nNonOrthCorr)
                    phi = phiHbyA - pEqn.flux();
            #include "continuityErrs.H"
             U -= rUA*fvc::grad(p);
             U.correctBoundaryConditions();
        fvScalarMatrix TEqn
            fvm::ddt(T)
            + fvm::div(phi, T)
            - fvm::laplacian(DT, T)
        TEqn.solve();
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
By using the command wmake, has:
Making dependency list for source file icoFoamTemp.C
SOURCE=icoFoamTemp.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam222/src/finiteVolume/lnInclude -I/opt/openfoam222/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam222/src/OpenFOAM/lnInclude -I/opt/openfoam222/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/icoFoamTemp.o
icoFoamTemp.C: Na função ‘int main(int, char**)’:
icoFoamTemp.C:100:19: erro: ‘rUA’ was not declared in this scope
/opt/openfoam222/src/finiteVolume/lnInclude/readPISOControls.H:3:15: aviso: unused variable ‘nOuterCorr’ [-Wunused-variable]
/opt/openfoam222/src/finiteVolume/lnInclude/readPISOControls.H:12:16: aviso: unused variable ‘momentumPredictor’ [-Wunused-variable]
/opt/openfoam222/src/finiteVolume/lnInclude/readPISOControls.H:15:16: aviso: unused variable ‘transonic’ [-Wunused-variable]
make: ** [Make/linux64GccDPOpt/icoFoamTemp.o] Erro 1
jrsilvio_ver is offline   Reply With Quote
Old   February 14, 2014, 23:18
JuNNioR
fvSchemes
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linear; //NOTICE: there is no space between the comma and the variables
    div(phi,T)      Gauss upwind;
laplacianSchemes
    default         none;
    laplacian(nu,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DT,T) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(HbyA) linear;
snGradSchemes
    default         orthogonal;
fluxRequired
    default         no;
    p               ;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0;
    // GW Add a solver for T
    T
        solver          BICCG;
        preconditioner  DILU; //GW or: none, GAMG, diagonal
        tolerance       1e-7;
        relTol          0;
    U
        solver          PBiCG;
        tolerance       1e-06;
        relTol          0;
PISO
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
T
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      T;
dimensions       [0 0 0 1 0 0 0];
internalField    uniform 300;
boundaryField
    movingWall
        type        fixedValue;
        value       uniform 350;
    fixedWalls
        type        fixedValue;
        value       uniform 300;
    frontAndBack
        type        empty;
Old   February 15, 2014, 12:45
JuNNioR
Can anyone help me identify the problem?
Old   February 16, 2014, 03:58
shinji nakagawa
snak is on a distinguished road
You got an error in compilation. How did you execute new solver?
Error message says unknown word ‘rUA’ exists in line 100 of icoFoamTemp.C.
Yes, its true. What is rUA? It will be rAU, isn't it?
snak is offline   Reply With Quote
Old   February 16, 2014, 17:47
JuNNioR
Mr. Nakagawa,
Firstly thank you very much for your help.
I modified the solver icoFOAM as the tutorial link: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
Really, it was the correct rAU.
But when running the modified ICOFOAM, the temperature field is still not appearing in the solution presented by PARAFOAM. Temperatures simply disappear.
Wmake command again, we have:
silvio@ubuntu:~/OpenFOAM/silvio-2.2.2/applications/solvers/icoFoamTemp$ wmake
/opt/openfoam222/src/finiteVolume/lnInclude/readPISOControls.H: Na função ‘int main(int, char**)’:
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam222/src/finiteVolume/lnInclude -I/opt/openfoam222/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam222/src/OpenFOAM/lnInclude -I/opt/openfoam222/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/icoFoamTemp.o -L/opt/openfoam222/platforms/linux64GccDPOpt/lib \
-lfiniteVolume -lsampling -lOpenFOAM -ldl -lm -o /home/silvio/OpenFOAM/silvio-2.2.2/platforms/linux64GccDPOpt/bin/my_icoFoamTemp
What can be the problem?
Old   February 16, 2014, 21:48
JuNNioR
No suggestion?
Old   February 16, 2014, 23:08
shinji nakagawa
Questions:
(1) Did you do "icoFoamTemp" instead of "icoFoam"?
(2) what exactly happens? "Temperatures simply disappear. "
Do you have a T file in time directories?
Please provide clear, concise and complete information about what you did and what you got.
Old   February 17, 2014, 17:34
JuNNioR
(1) I used the command icoFoamTemp. I did not use command icoFoam .
(2) When displaying the simulated results by command paraFoam, check that the temperature disappears over time. That is, at time t = 0, s is the temperature field and as time goes by following the temperature disappears.
What can be happening?
Below, we have the result of ControlDict and icoFoamTemp command.
Time = 0.495
Courant Number mean: 0.222159 max: 0.852134
DILUPBiCG: Solving for Ux, Initial residual = 3.77171e-08, Final residual = 3.77171e-08, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 8.93865e-08, Final residual = 8.93865e-08, No Iterations 0
DICPCG: Solving for p, Initial residual = 7.67456e-07, Final residual = 7.67456e-07, No Iterations 0
time step continuity errors : sum local = 7.3935e-09, global = -1.93974e-19, cumulative = -1.32121e-17
DICPCG: Solving for p, Initial residual = 9.33333e-07, Final residual = 9.33333e-07, No Iterations 0
time step continuity errors : sum local = 8.75324e-09, global = 8.34212e-19, cumulative = -1.23778e-17
ExecutionTime = 0.23 s ClockTime = 0 s
Time = 0.5
DILUPBiCG: Solving for Ux, Initial residual = 3.10465e-08, Final residual = 3.10465e-08, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 7.20119e-08, Final residual = 7.20119e-08, No Iterations 0
DICPCG: Solving for p, Initial residual = 1.08094e-06, Final residual = 1.61882e-07, No Iterations 1
time step continuity errors : sum local = 2.42633e-09, global = 1.12397e-18, cumulative = -1.12539e-17
DICPCG: Solving for p, Initial residual = 4.79724e-07, Final residual = 4.79724e-07, No Iterations 0
time step continuity errors : sum local = 5.02954e-09, global = -1.26633e-18, cumulative = -1.25202e-17
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
ControlDict
application icoFoamTemp;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 0.5;
deltaT 0.005;
writeControl timeStep;
writeInterval 20;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
Old   February 17, 2014, 20:57
shinji nakagawa
hi,
I read your #5 post again and found the cause of the problem.
Your new solver will be "my_icoFoamTemp" which is shown in the last line of wmake output.
It is written in "files" file in Make subdirectory.
Running my_icoFoamTemp will do what you want to do with your posted source code.
I don't know what is icoFoamTemp in your system. Have you make a solver in that name before? It should be...
This is the reason why you have been able to execute icoFoamTemp before you successfully compile the code, I think.
Old   February 18, 2014, 00:10
JuNNioR
Problem solved.
The error was in charge.
Thank you for your attention.
Thread Tools
Trackbacks are On
Problems adding temperature to icoFoam sur4j OpenFOAM Programming & Development 8 January 11, 2015 02:14
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 11 April 22, 2014 12:32
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
adding temperature field to icofoam houkensjtu OpenFOAM 5 September 26, 2012 22:20
