Home > Forums > OpenFOAM Programming & Development
Adaptive time step control for generic problems
Old   February 18, 2014, 04:28
Default Adaptive time step control for generic problems
chriss85 is on a distinguished road
I'm working on a solver that employs other equations than flow, like radiation and electromagnetic equations.
The solver is very dependent on the time step size, it quickly diverges and crashes if it gets too high. I'm wondering if I can implement a time step control that considers every field, and not just the flow. I found this post for residual based time step control:
Time in OpenFOAM
Is this a feasible approach for transient problems where no steady solution is expected, due to unsteady boundary conditions?
What kind of control loop would I use? A PID loop, separately for each residual, and use the minimum time step then?
Or are there other methods I could try for stabilizing the solver? Maybe use different schemes? Unfortunately robust schemes like upwind make no sense for equations unrelated to the flow...are there others that could be used here?
chriss85 is offline   Reply With Quote
Old   February 18, 2014, 10:14
I have it half-way working for absolute tolerances...
I added a residualDict:
IOdictionary residualDict
    IOobject
        "residualDict",
        runTime.system(),
        mesh,
        IOobject::MUST_READ,
        IOobject::NO_WRITE
dictionary relDict(residualDict.subDict("relative"));
dictionary absDict(residualDict.subDict("absolute"));
And then calculate a measure for an error indicator:
forAll(absDict.toc(), i)
            if(mesh.solverPerformanceDict().lookupEntry(absDict.toc()[i]) != NULL)
                List<solverPerformance> perf = mesh.solverPerformanceDict().lookup(absDict.toc()[i]);
                scalar delta = perf.first().initialResidual() - absDict.lookupOrDefault<scalar>(absDict.toc()[i], 1e-3);
                Info << absDict.toc()[i] << ": "  << perf.first().initialResidual() << " - " << absDict.lookupOrDefault<scalar>(absDict.toc()[i], 1e-3) << " = " << delta << endl;
                absError = i == 0 ? delta : max(absError, delta);
        Info << "absError: " << absError << endl << "deltaT: " << runTime.deltaT() << " --> ";
        if(absError < 0)
            runTime.setDeltaT(runTime.deltaT() * residualDict.lookupOrDefault<scalar>("increase", 1.1));
        else
            runTime.setDeltaT(runTime.deltaT() / residualDict.lookupOrDefault<scalar>("decrease", 2));
In general this is working, however, I have some issues with vectorFields. The residual stored in solverPerformance is only of scalar type, looking in fvMatrixSolve.C reveals that it's the maximum component of the vector. I would like to use individual residuals for every component though, which are also printed in the console.
Is there any other place where OF exposes the residual data, or do I need to modify the OF core files for this?
Relative tolerances aren't implemented yet, but will be in the future. I'll post the example code as reference then.
Having relative tolerances requires storing the initial residuals from a previous time step, by doing this I also get the benefit of being able to use a PID loop instead of this simple control loop here.
Old   February 18, 2014, 11:05
Joachim Herb
jherb is on a distinguished road
This bug report and the links within it might help:
http://www.openfoam.org/mantisbt/view.php?id=270
jherb is offline   Reply With Quote
Thread Tools
Trackbacks are On
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
Time step size with adaptive time steps Racing_34 CFX 3 April 14, 2013 18:32
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
