Home > Forums > OpenFOAM Programming & Development
Eclipse & OpenFoam
Like Tree1Likes
Old   March 3, 2014, 05:21
maybee is on a distinguished road
hi,
thx again for the help, but still eclipse does not work. The solver files as well as the workspace folder are already in my home folder. So I tried using "sudo eclipse", but i get the output when building:
/opt/openfoam221/wmake/wmake all
wmake error: environment variable $WM_OPTIONS not set
10:13:14 Build Finished (took 88ms)
and when running the error:
Launch failed.Binary not found!
If I am starting eclipse only with the command "eclipse" I get the messages mentioned in my previous post.
maybee is offline   Reply With Quote
Old   March 3, 2014, 05:39
Jianzhi Li
epi_c is on a distinguished road
Send a message via Skype™ to epi_c
Sorry, I can not do anything more.
I installed OpenFOAM in $HOME/OpenFOAM using source code, and I think that's why I didn't have problems.
epi_c is offline   Reply With Quote
Old   March 5, 2014, 11:26
Jianzhi Li
@maybee hi,
I found a more useful tool at http://openfoamwiki.net/index.php/Ho...with_QtCreator, it is easy to use, I used just 20 minutes to install QtCreator and run a project successfully.
maybee likes this.
Old   March 5, 2014, 11:28
Thx, I ll try this tomorrow
Edit: Works fine - best and easiest solution : QTCreator !
Thread Tools
Trackbacks are On
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 07:18
ESI-OpenCFD Releases OpenFOAM v2.2.0 opencfd OpenFOAM Announcements from ESI-OpenCFD 13 March 30, 2013 17:52
gmsh 2.6.0 conversion to OpenFoam 160 rosswin Open Source Meshers: Gmsh, Netgen, CGNS, ... 0 March 5, 2013 08:34
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 07:14
