Home > Forums > OpenFOAM Programming & Development
problem in writing a solver for a 3-step runge kutta(incompressible flow)
Old   February 24, 2014, 14:03
Default problem in writing a solver for a 3-step runge kutta(incompressible flow)
ooo
ooo is on a distinguished road
I'm implementing a 3-step runge kutta descritization for solving incompressible flow.
The results are completely wrong.
I would appreciate if you have a look at the code below and tell me if you see any problem :
while (runTime.loop())
 double alpha,gamma,zeta;
 volVectorField Unew(U), UOld2(U), UTmp(U) ;
 surfaceScalarField phiOld2(phi), phiTmp(phi);
 volScalarField pPhi(p);
        for (int i = 1 ;  i<=3 ; ++i)
            switch (i)
                case 1 : {UOld2=U ; phiOld2=phi ; alpha=4./15. ; gamma= 8./15. ; zeta =0.; break ; }
                case 2 : {UTmp=U ; phiTmp=phi ; alpha=1./15. ; gamma= 5./12. ; zeta =-17./60.; break ; }
                case 3 : {UOld2=UTmp ; phiOld2=phiTmp ; alpha=1./6. ; gamma= 3./4. ; zeta =-5./12.; break ; }
                default : break ;
        adjustPhi(phi, U, p);
        U = U + runTime.deltaT() *
         + 2*alpha*fvc::laplacian(nu,U)
         - 2*alpha*fvc::grad(p)
         - gamma*fvc::div(phi, U)
         - zeta*fvc::div(phiOld2, UOld2)
      solve(alpha*runTime.deltaT()*fvm::laplacian(nu,Unew) - fvm::Sp(1.,Unew)  == //(alpha*runTime.deltaT())  ==
      (-1.)*(U) + alpha*runTime.deltaT()*fvc::laplacian(nu,U) );
      solve (fvm::laplacian(pPhi) == fvc::div(U)/(2.*alpha*runTime.deltaT()));
      U =  Unew - (2.*alpha*runTime.deltaT()*fvc::grad(pPhi));
      p += pPhi - alpha*runTime.deltaT()*nu*(fvc::laplacian(pPhi));
         U.correctBoundaryConditions();
runTime.write();
ooo is offline   Reply With Quote
Old   March 4, 2014, 12:19
ooo
I make my code shorter, maybe someone has any idea regarding any problem on this kind of implementation :
      solve (fvm::laplacian(pPhi) == fvc::div(U)/(2.*alpha*runTime.deltaT()));// pPhi is a pseudo pressure without physical meaning
Thread Tools
Trackbacks are On
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Maximum words supported by the flow solver exceeded rae CFX 3 June 6, 2013 06:49
Problem with changing mass flow rate roo FLUENT 3 June 4, 2013 14:53
On Setring Step Size in unsteady Solver of FLUENT lzgwhy FLUENT 0 August 19, 2009 22:44
