Computing the heat flux vector in OpenFoam
Old   May 3, 2022, 11:16
Default Computing the heat flux vector in OpenFoam
Nikos Vasileiadis
nikovasi is on a distinguished road
Hello to everyone,
I am new to OpenFoam. I have a simple laminar simulation and I want to compute and output the heat flux vector (thermalConductivity*grad(T)) for all the cells of my domain. I have found that you can get the heat flux normal to the domain boundaries using the wallHeatFlux utility. However, I cannot find anything helpful on the heat flux vector in a cell. I would be grateful if anyone can provide a solution or point me towards one.
Thanks for any help.
nikovasi is offline   Reply With Quote
Old   July 9, 2022, 19:22
Joachim Herb
jherb is on a distinguished road
I guess you use paraview? Have you loaded the also the paches. The heat flux field should be defined on the walls (and in the cells of the internal field).
jherb is offline   Reply With Quote
heat flux in a cell, heat transfer
Simulating constant heat flux value at solid-solid boundary Y27 STAR-CCM+ 6 September 8, 2020 09:56
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
Monitor Heat Flux in CFD-Pre cltormar CFX 5 November 20, 2014 11:45
Calculating heat flux in OpenFOAM eretief OpenFOAM Programming & Development 1 May 19, 2014 10:15
