-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Read parallel meshes (http://www.cfd-online.com/Forums/openfoam-programming-development/130762-read-parallel-meshes.html)
dl6tud March 4, 2014 05:44
I would like to read the meshes of all processors when computing in parallel. The idea is to have all meshes on each processor.
I create a "Time-Object" for each processor as
PtrList<Time> time(Pstream::nProcs());
forAll(time, procI)
time.set
procI,
new Time
Time::controlDictName,
args.rootPath(),
args.globalCaseName()/fileName(word("processor") + name(procI))
Then, I create the meshes with
PtrList<fvMesh> pMesh(Pstream::nProcs());
forAll(pMesh, procI)
pMesh.set
procI,
new fvMesh
IOobject
Foam::fvMesh::defaultRegion,
time[procI].timeName(),
time[procI],
IOobject::MUST_READ
The second step fails with
Message from processor 0 not fully consumed. messageSize:20620 bytes of which only 0 consumed.
At the moment I have no idea, why OF tries to communicate with the other processors when reading the meshes. Maybe for the boundaries?
ngj March 5, 2014 14:04
Yes, the processor boundaries exchange information, so what you are trying to do will most probably not work.
May I ask, why you need all the meshes on every processor?
Kind regards,
Niels
A_Pete March 7, 2014 04:45
what about using gather and scatter? Not sure what you exactly want to do with the mesh, but you could use gatherList.
//- Get local mesh on processor
fvMesh mesh(refCast<const fvMesh>(obr_));
//- Gather the meshes into PtrList on master processor
pMesh[Pstream::myProcNo()] = mesh;
Pstream::gatherList(pMesh);
Depending on what you want to do afterwards, you could either use scatterList or put the mesh together again from the pMesh and then scatter just this fvMesh.
