Home > Forums > OpenFOAM Programming & Development
calcAlphas() of multiphaseSystem
Like Tree1Likes
  • 1 Post By GerhardHolzinger
Old   March 12, 2014, 05:43
Default calcAlphas() of multiphaseSystem
maybee is on a distinguished road
hi,
I don`t understand method calcAlphas() of multiphaseSystem
void Foam::multiphaseSystem::calcAlphas()
   48 {
   49     scalar level = 0.0;
   50     alphas_ == 0.0;
   51
   52     forAllIter(PtrDictionary<phaseModel>, phases_, iter)
   53     {
   54         alphas_ += level*iter();  //volScalarField alphas_
   55         level += 1.0;
   56     }
   57
   58     alphas_.correctBoundaryConditions();
   59 }
By the "forAllIter" Macro we iterate through all objects of type "phaseModel" which should be the phasefractions of the different phases in first place, right?
If this is right I don`t understand what is calculated with this procedure. As far as I understand line 54 would technically mean the following
volScalarField alphas_ = phasefraction1*0 + phasefraction2*1 + phasefraction3*2 ...
Initially I thought volScalarField alphas_ would just be the sum of all phasefraction fields of the different phases, but when I look at the code it does not seem so.
What is calculated here?
greetings maybee
maybee is offline   Reply With Quote
Old   March 12, 2014, 05:50
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
The sum of the volume fractions of all phases must be 1. There is little information in field that is 1 throughout the domain.
The intention behind alphas is to provide one field to visualize all phases.
If you have a water-oil-air system, you have three volume fraction fields. Three fields are hard to visualize in one image. This is where alphas comes to the rescue.
In the alphas field 0 means water, 1 means oil and 2 means air. This way you can depict all phases at once.
GerhardHolzinger is offline   Reply With Quote
Old   March 12, 2014, 06:05
Thx, nice idea, but I am thinking about the following now:
Let s assume we have initial water-oil-air alpha fields like
water
1
1
1
1
0
0
0
oil
0
0
0
0
0.3
0.5
0.7
air
0
0
0
0
0.7
0.5
0.3
So, the resulting volScalarField alphas_ would be something like
alphas_
0
0
0
0
1*0.3 + 2*0.7 = 1.7
1*0,5 + 2*0.5 = 1.5
1*0.7 + 2*0.3 = 1.3
Your visualization theory in which 0 is water, 1 is oil and 2 is air would only work if each cell is initially full of water OR oil OR air, right?
Isn`t this some kind of limitating at least the intitial conditions of the cells if only 0 or 1 for each phase in a cell were possible?
Old   March 12, 2014, 06:32
Gerhard Holzinger
Yes, you can have values in between. I attached the alphas field from the damBreak4phase tutorial case of multiphaseEulerFoam.
The phases are water-oil-mercury-air.
If you have any doubts or ideas. Play with the tutorial case.
maybee likes this.
Thread Tools
Trackbacks are On
multiphaseEulerFoam: PtrDictionary<phaseModel> phases_ of multiphasesystem fluid maybee OpenFOAM Programming & Development 9 January 27, 2014 07:24
method solve() of class multiphasesystem maybee OpenFOAM Programming & Development 2 December 14, 2013 12:55
