chtMultiRegionFoam boundary condition
Old   March 14, 2014, 04:28
Default chtMultiRegionFoam boundary condition
Norbert Weber
dl6tud is on a distinguished road
I wonder, why the boundary condition for chtMultiRegionFoam is implemented as mixed and not as fixedValue.
How the boundary "turbulentTemperatureCoupledBaffleMixed" works, is explained here http://www.cfd-online.com/Forums/ope...condition.html
For explanation see picture. Temperatur (T) has to be equal at the boundary as well as the normal heat flow (q). Here, they combine the two boundary conditions into one. Tw is wall Temperature, T1 internal field of phase one T2 of phase two. Delta is the distance cell center to face center, n normal vector.
So basically we have a wall temperature given, fullfilling both boundary conditions. I would base this on fixedValue, but it does not work (does not converge).
In cht they base it on mixed with
Tw = refValue*valueFraction + (1-valueFraction)*(Tinternal + refGradient*delta).
If you use the values provided in turbulentTemperatureCoupledBaffleMixed, you get exactly the formula, but why so complicated? Any hints?
    // Both sides agree on
    // - temperature : (myKDelta*fld + nbrKDelta*nbrFld)/(myKDelta+nbrKDelta)
    // - gradient    : (temperature-fld)*delta
    // We've got a degree of freedom in how to implement this in a mixed bc.
    // (what gradient, what fixedValue and mixing coefficient)
    // Two reasonable choices:
    // 1. specify above temperature on one side (preferentially the high side)
    //    and above gradient on the other. So this will switch between pure
    //    fixedvalue and pure fixedgradient
    // 2. specify gradient and temperature such that the equations are the
    //    same on both sides. This leads to the choice of
    //    - refGradient = zero gradient
    //    - refValue = neighbour value
    //    - mixFraction = nbrKDelta / (nbrKDelta + myKDelta())
dl6tud is offline   Reply With Quote
Radiation interface hinca CFX 15 January 26, 2014 17:11
conjugate boundary condition Daniel_Khazaei OpenFOAM Programming & Development 0 December 31, 2013 13:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Opening Boundary Condition andreachan Main CFD Forum 11 March 19, 2013 16:46
