March 15, 2014, 04:45 |
error from fvc::reconstruct !!!!
Hi everybody,
I'm trying to add energy equation to porousSimpleFoam and I faced this error when I wanted to wmake my solver: (this is part of the error appeared in my terminal) Code:
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvMatrix.C:2140:34: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::operator+(const Foam::dimensioned<Type>&, const Foam::tmp<Foam::fvMatrix<Type> >&) In file included from doubleDiffPorousSimpleFoam.C:83:0: pEqn.H:55:41: error: ‘faceInterpolate’ is not a member of ‘Foam::fvc’ In file included from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/doubleFloat.H:30:0, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/floatScalar.H:38, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/scalar.H:39, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/IOstream.H:49, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Ostream.H:39, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/OSstream.H:40, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/messageStream.H:211, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/error.H:51, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/UListI.H:26, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/UList.H:365, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/List.H:43, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/labelList.H:48, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/UPstream.H:43, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Pstream.H:42, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/parRun.H:35, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvCFD.H:4, from doubleDiffPorousSimpleFoam.C:48: /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/products.H: At global scope: /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/products.H: In instantiation of ‘Foam::outerProduct<Foam::Vector<double>, Foam::Tensor<double> >’: pEqn.H:56:68: instantiated from here /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/products.H:72:13: error: no type named ‘type’ in ‘class Foam::typeOfRank<double, 3>’ In file included from doubleDiffPorousSimpleFoam.C:83:0: pEqn.H: In function ‘int main(int, char**)’: pEqn.H:56:68: error: no matching function for call to ‘reconstruct(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvsPatchField, Foam::surfaceMesh> >)’ pEqn.H:56:68: note: candidates are: /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvcReconstruct.C:50:1: note: template<class Type> Foam::tmp<Foam::GeometricField<typename Foam::outerProduct<Foam::Vector<double>, Type>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::reconstruct(const Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh>&) /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvcReconstruct.C:91:1: note: template<class Type> Foam::tmp<Foam::GeometricField<typename Foam::outerProduct<Foam::Vector<double>, Type>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::reconstruct(const Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> >&) make: *** [Make/linux64GccDPOpt/doubleDiffPorousSimpleFoam.o] Error 1 Code:
tmp<volTensorField> tTU = tensor(I)*UEqn().A(); surfaceTensorField tUf("(1|TA(U))", fvc::faceInterpolate(tTU())); U -= trTU()&fvc::reconstruct((buoyancyPhi + tpEqn().flux())*tUf); I guess that reconstruct cannot handle tonsorial input!!! If yes, what should I use instead of reconstruct? any tips appreciated Regards, Mostafa Last edited by adambarfi; March 17, 2014 at 09:04. |
March 16, 2014, 05:24 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Mostafa,
The issue is (at least) the fact that you are parsing a tmp<> object to reconstruct. The following line would strip away the tmp-type: Code:
U -= trTU&fvc::reconstruct((buoyancyPhi + tpEqn().flux()())*tUf); Good luck, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
March 17, 2014, 09:01 |
thank you Niels,
I surfed the internet and found that I had a wrong definition of fvc::reconstract in my mind. Best, Mostafa |
fvc::reconstruct( ) algorithm | tetraeder | OpenFOAM Programming & Development | 17 | April 17, 2021 10:23 |
fvc::reconstruct( ) algorithm | Dieth01 | OpenFOAM Programming & Development | 0 | January 29, 2014 21:23 |
