Home > Forums > OpenFOAM Programming & Development
limiter function in openfoam
Old   March 19, 2014, 19:07
Question limiter function in openfoam
openfoammaofnepo is on a distinguished road
Dear All,
In the openfoam limiter function, there is a scalar called k_, does anybody know what does it stand for? For example, we can have a look at the limiter for Gamma differencing:
    GammaLimiter(Istream& is)
        k_(readScalar(is))
        if (k_ < 0 || k_ > 1)
            FatalIOErrorIn("GammaLimiter(Istream& is)", is)
                << "coefficient = " << k_
                << " should be >= 0 and <= 1"
                << exit(FatalIOError);
        // Rescale k_ to be >= 0 and <= 0.5 (TVD conformant)
        // and avoid the /0 when k_ = 0
        k_ = max(k_/2.0, SMALL);
The above code lines are from:
OpenFOAM/OpenFOAM-<version>/src/finiteVolume/interpolation/surfaceInterpolation/limitedSchemes/Gamma/Gamma.H
The second question is: we need the calculate the gradiant ratio for the limiter function (always the input for the limiter). In TVD scheme, we call it r and in NVD we call it phict. These two quantities are defined in:
OpenFOAM/OpenFOAM-<version>/src/finiteVolume/interpolation/surfaceInterpolation/limitedSchemes/LimitedScheme/NVDTVD.H
When calculating r or phict, we need to get the difference of phi in Cell N and P (actually upwind and downwind cells). Take r for example. The original code is:
        scalar r
            const scalar faceFlux,
            const scalar phiP,
            const scalar phiN,
            const vector& gradcP,
            const vector& gradcN,
            const vector& d
        ) const
            scalar gradf = phiN - phiP;
            scalar gradcf;
            if (faceFlux > 0)
                gradcf = d & gradcP;
            else
                gradcf = d & gradcN;
            if (mag(gradcf) >= 1000*mag(gradf))
                return 2*1000*sign(gradcf)*sign(gradf) - 1;
            else
                return 2*(gradcf/gradf) - 1;
In my opinion, it should be like:
        scalar r
            const scalar phiP,
            const scalar phiN,
            const vector& d
        ) const
            scalar gradcf;
            if (faceFlux > 0)
            else
                scalar gradf = phiP - phiN;
            else
About this issue, I am not sure this is a bug or I make some mistakes here. In my opinion, gradf depends on the direction of flow, i.e. upwind or downwind, but as you know owner and neighbor cells only stands for the geometrical position, instead of any flow direction information. Does anybody have some comments here?
OFFO
openfoammaofnepo is offline   Reply With Quote
Thread Tools
Trackbacks are On
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 98 October 18, 2014 15:43
Production limiter only used for k - kOmegaSST - OpenFOAM 2.2.x Bokse OpenFOAM Programming & Development 7 March 3, 2014 18:11
probes function not working in Openfoam 2.1.1 nandiganavishal OpenFOAM 7 July 26, 2012 11:06
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 09:53
Version 15 on Mac OS X gschaider OpenFOAM Installation 120 December 2, 2009 11:23
